My Polyline Hatch code has terrible error and does not work.
MarkJamesRogolino
Message 1 of 8
MarkJamesRogolino
Hello all the thankful persons.
Now I am making polyline hatch application but it does not work and error.
I am stunned because of this problem.
Followings are my error image and code.
I hope someone can help me. Thanks in advance.
public static void Hatch()
            var documentManager = Application.DocumentManager;
            var currentDocument = documentManager.MdiActiveDocument;
            var db = currentDocument.Database;
            var ed = currentDocument.Editor;
            using (var tr = db.TransactionManager.StartOpenCloseTransaction())
                var blockTable = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                foreach (ObjectId btrId in blockTable)
                    var btr = (BlockTableRecord)tr.GetObject(btrId, OpenMode.ForWrite);
                    var PlineCls = RXObject.GetClass(typeof(Polyline));
                    if (btr.IsLayout)
                        foreach (ObjectId id in btr)
                            if (id.ObjectClass == PlineCls)
                                var pline = (Polyline)tr.GetObject(id, OpenMode.ForRead);
                                string curlay = pline.Layer;
                                if (IsreqHatch(curlay) == true)
                                    ObjectIdCollection acObjIdColl = new ObjectIdCollection();
                                    acObjIdColl.Add(pline.ObjectId);
                                    Hatch acHatch = new Hatch();
                                    btr.AppendEntity(acHatch);
                                    tr.AddNewlyCreatedDBObject(acHatch, true);
                                    acHatch.SetDatabaseDefaults();
                                    acHatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI31");
                                    acHatch.Associative = true;
                                    acHatch.HatchStyle = HatchStyle.Ignore;
                                    acHatch.AppendLoop(HatchLoopTypes.Outermost, acObjIdColl);
                                    acHatch.EvaluateHatch(true);
                tr.Commit();
Replies (7)
Message 2 of 8
_gile
You have to set the hatch pattern before adding it to the Database.
One more time, build a little method to hatch a single polyline so that you can test-it and debug it by selection a single polyline with a simple test command instead of running your method which iterates through each entity of each layout.
        private static void HacthPolyline(Polyline pline, BlockTableRecord btr, Transaction tr)
            var ids = new ObjectIdCollection();
            ids.Add(pline.Id);
            var hatch = new Hatch { Layer = pline.Layer };
            hatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI31");
            btr.AppendEntity(hatch);
            tr.AddNewlyCreatedDBObject(hatch, true);
            hatch.Associative = true;
            hatch.AppendLoop(HatchLoopTypes.Default, ids);
            hatch.EvaluateHatch(true);
And, when you're satified with this method, you can integrate it into your main method:
                    if (btr.IsLayout)
                                if (IsreqHatch(pline.Layer))
                                    HacthPolyline(pline, btr, tr);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
MarkJamesRogolino
well done. Thanks, gile. but is it possible to manage spacing?
Message 4 of 8
_gile
You can set the Hatch poperties when you create the new instance:
var hatch = new Hatch { Layer = pline.Layer, PatternScale = 2.0 };
or
var hatch = new Hatch();
hatch.Layer = pline.Layer;
hatch.PatternScale = 2.0;
Gilles Chanteau
GileCAD
GitHub
Message 5 of 8
MarkJamesRogolino
You are very very talented person.
Message 6 of 8
kerry_w_brown
and very generous !
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 7 of 8
MarkJamesRogolino
Hi, _gile. I am currently getting this error.
could you tell me why this error occurs?
I hope your answer.
Message 8 of 8
_gile
What if you try to hatch this polyline with the native command ?
Gilles Chanteau
GileCAD
GitHub
