Make a jig of aligned dimensions
BIM_VIET
BIM_VIET
Dear All,
I want to make a collection of aligned Dimension by make a Fence selection intersect with some line or polyline.
Step 1: I got the the collection of intersection points,
Step 2: Please help how to make a jig of aligned dimensions like picture below:
_gile
Here's an example:
        [CommandMethod("TEST")]
        public static void Test()
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var options = new PromptPointOptions("\nFirst point: ");
            var result = ed.GetPoint(options);
            if (result.Status != PromptStatus.OK) return;
            var pt1 = result.Value;
            options.Message = "\nSecond point: ";
            options.UseBasePoint = true;
            options.BasePoint = pt1;
            var pt2 = result.Value;
            var fence = new Point3dCollection(new[] { pt1, pt2 });
            var filter = new SelectionFilter(new[] { new TypedValue(0, "LINE,LWPOLYLINE") });
            var selection = ed.SelectFence(fence, filter);
            if (selection.Status != PromptStatus.OK) return;
            using (var tr = db.TransactionManager.StartTransaction())
            using (var line = new Line(pt1, pt2))
                line.TransformBy(ed.CurrentUserCoordinateSystem);
                var points = new Point3dCollection();
                foreach (ObjectId id in selection.Value.GetObjectIds())
                    var curve = (Curve)tr.GetObject(id, OpenMode.ForRead);
                    curve.IntersectWith(line, Intersect.OnBothOperands, points, IntPtr.Zero, IntPtr.Zero);
                var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                var dims = new List<AlignedDimension>();
                for (int i = 0; i < points.Count - 1; i++)
                    var dim = new AlignedDimension(points[i], points[i + 1], points[i], "", db.Dimstyle);
                    curSpace.AppendEntity(dim);
                    tr.AddNewlyCreatedDBObject(dim, true);
                    dims.Add(dim);
                var jig = new AlignedDimensionsJig(dims);
                var pr = ed.Drag(jig);
                if (pr.Status != PromptStatus.OK)
                    foreach (var dim in dims)
                        dim.Erase();
                tr.Commit();
        class AlignedDimensionsJig : DrawJig
            List<AlignedDimension> dims;
            Point3d dragPoint;
            public AlignedDimensionsJig(List<AlignedDimension> dims)
            { this.dims = dims; }
            protected override SamplerStatus Sampler(JigPrompts prompts)
                var options = new JigPromptPointOptions("\nSpecify Dimension Line Location: ");
                options.UserInputControls =
                    UserInputControls.Accept3dCoordinates | UserInputControls.GovernedByUCSDetect;
                var result = prompts.AcquirePoint(options);
                if (result.Value.IsEqualTo(dragPoint)) return SamplerStatus.NoChange;
                dragPoint = result.Value;
                return SamplerStatus.OK;
            protected override bool WorldDraw(WorldDraw draw)
                    dim.DimLinePoint = dragPoint;
                    dim.Draw();
                return true;
Gilles Chanteau
GileCAD
GitHub
_gile
In a more conventional way (entities are added to the Database only if the Jig result is OK).
                    dim.SetDatabaseDefaults();
                    dims.Add(dim);
                if (pr.Status == PromptStatus.OK)
                else
                        dim.Dispose();
                tr.Commit();
            Point3d dragPoint;
                var geometry = draw.Geometry;
                if (geometry != null)
                        geometry.Draw(dim);
                return true;
Gilles Chanteau
GileCAD
GitHub
BIM_VIET
Dear @_gile ,
Thank you for your code. it run perfectly.
Now I would like to update a Jig with Aligned Dimension & Arc Length Dimension when pick 1 or more polylines as the picture below, Please help how to do that.
_gile
Didn't my first replies help you ?
You should be able to adapt the above code to fit your new request.
Gilles Chanteau
GileCAD
GitHub
BIM_VIET
hi @_gile ,
Yes your code is help me in first one. thank you very much
