Announcements
Loft Surface issue
swapnil_lokam
Loft Surface issue
swapnil_lokam
Hi there,
I am trying to create a loft surface using a list of spline entities
These splines are created using a geographical 3D coordinates
My code is working perfectly fine (check the code below in the snap )
This is how I am creating surface in AutoCAD 2024
The above surface consists of around 25 splines each of length 745 units
using all these splines I am creating a loft surface
but when I am trying to create a loft surface on clients model
I am facing performance issues in AutoCAD
The client model consists of around 200 splines each of length 15000 units
Even after waiting for around half an hour the surface is not being created on client's model
Is there any other method to create a loft surface in AutoCAD other than CreateLoftedSurface() method that would help to create a surface with large no.of splines and with each spline having length of around 15000 units without affecting the performance.
It would be great if anyone can help me with the issue.
Thanks in advance....!!!
ActivistInvestor
The symptom you describe suggests a memory issue. How much physical memory do the system(s) that exhibit the performance issues have installed on them?
Also, in terms of memory consumption and execution time, the length of the splines is not relevant. It has more to do with the density of the splines (the number of control or fit points each spline has).
Another thing you might want to do is compare the values of relevant system variables between your system and the ones having the performance issues.
swapnil_lokam
The number of control points on each splines are around 435 points and there are 200 such splines
Is there any other way to create a surface using the control points which would not result in performance issue
ActivistInvestor
Not that I'm aware of. Using the control points directly as vertices would not have the same result.
One thing you could try is to create the surface in an in-memory Database created via the Database constructor, and then clone or insert the surface into the active document once it's created.
Did you investigate the other variables I noted (related system variable differences, and installed memory)?
Izhar_Azati
You wrote that you are using geographical 3D coordinates
I would try to "move" the data to the 0,0,0 area
Another thing, for many years there have been more practical forms for describing land surfaces, such as DTM
ActivistInvestor
Moving the geometry closer to the origin could affect the accuracy of the result, but not how long it takes to get there.
