Loading and plotting a drawing via .NET
kelly
Message 1 of 1
kelly
Similar to the example shown here (https://www.keanw.com/2007/09/driving-a-basic.html),  I put together a plugin to load a drawing and then plot it. The line weights, however, don't match my current plot style consistently. If I adjust the code to plot the active document it plots just fine but when I revised the code to load a drawing then plot it is when I noticed it plotting incorrectly. The odd thing is that the test drawing that I was plotting seemed to plot fine with a certain layer in place. If I delete the layer (even though nothing is on that layer) then the error occurs. Below is the code, any suggestions as to a fix would be appreciated.
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.PlottingServices;
namespace SimplePlot
    public class PlottingCommands
        [CommandMethod("simplot")]
        public static void SimplePlot()
            Document doc_org = Application.DocumentManager.MdiActiveDocument;
            Editor ed_org = doc_org.Editor;
            Database db_org = doc_org.Database;
            string FileName2 = "\\\\projects\\temp\\test2.dwg";
            using (Database db = new Database(false, true))
                db.ReadDwgFile(FileName2, System.IO.FileShare.Read, false, null);
                db.CloseInput(true);
                db.UpdateExt(true);
                HostApplicationServices.WorkingDatabase = db;
                var plSettings = new DBDictionary();
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead);
                    Layout lo = (Layout)tr.GetObject(btr.LayoutId, OpenMode.ForRead);
                    PlotInfo pi = new PlotInfo();
                    pi.Layout = btr.LayoutId;
                    PlotSettings ps = new PlotSettings(lo.ModelType);
                    ps.CopyFrom(lo);
                    PlotSettingsValidator psv = PlotSettingsValidator.Current;
                    psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents);
                    psv.SetUseStandardScale(ps, true);
                    psv.SetStdScaleType(ps, StdScaleType.ScaleToFit);
                    psv.SetPlotCentered(ps, true);
                    psv.SetPlotRotation(ps, PlotRotation.Degrees000);
                    psv.SetPlotConfigurationName(ps, "PostScript Level 2.pc3", null);
                    psv.RefreshLists(ps);
                    //Get the Canonical Media Name
                    string canonicalMediaName = LocalToCanonicalMediaName("EPS(3.5x3.5)", ps, psv);
                    //set the canonical media name
                    psv.SetCanonicalMediaName(ps, canonicalMediaName);
                    psv.SetCurrentStyleSheet(ps, "MYPRINTER.ctb");
                    pi.OverrideSettings = ps;
                    PlotInfoValidator piv = new PlotInfoValidator();
                    piv.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
                    piv.Validate(pi);
                    if (PlotFactory.ProcessPlotState == ProcessPlotState.NotPlotting)
                        PlotEngine pe = PlotFactory.CreatePublishEngine();
                        using (pe)
                            PlotProgressDialog ppd = new PlotProgressDialog(false, 1, true);
                            using (ppd)
                                ppd.set_PlotMsgString(PlotMessageIndex.DialogTitle, "Custom Plot Progress");
                                ppd.set_PlotMsgString(PlotMessageIndex.CancelJobButtonMessage, "Cancel Job");
                                ppd.set_PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage, "Cancel Sheet");
                                ppd.set_PlotMsgString(PlotMessageIndex.SheetSetProgressCaption, "Sheet Set Progress");
                                ppd.set_PlotMsgString(PlotMessageIndex.SheetProgressCaption, "Sheet Progress");
                                ppd.LowerPlotProgressRange = 0;
                                ppd.UpperPlotProgressRange = 100;
                                ppd.PlotProgressPos = 0;
                                ppd.OnBeginPlot();
                                ppd.IsVisible = true;
                                pe.BeginPlot(ppd, null);
                                string PlotPath = "\\\\projects\\temp\\test.eps";
                                // We'll be plotting a single document
                                pe.BeginDocument(
                                    pi,
                                    //docnew.Name,
                                    FileName2,
                                    null,
                                    1,
                                    true, // Let's plot to file
                                    PlotPath
                                // Which contains a single sheet
                                ppd.OnBeginSheet();
                                ppd.LowerSheetProgressRange = 0;
                                ppd.UpperSheetProgressRange = 100;
                                ppd.SheetProgressPos = 0;
                                PlotPageInfo ppi = new PlotPageInfo();
                                pe.BeginPage(ppi, pi, true, null);
                                pe.BeginGenerateGraphics(null);
                                pe.EndGenerateGraphics(null);
                                // Finish the sheet
                                pe.EndPage(null);
                                ppd.SheetProgressPos = 100;
                                ppd.OnEndSheet();
                                // Finish the document
                                pe.EndDocument(null);
                                // And finish the plot
                                ppd.PlotProgressPos = 100;
                                ppd.OnEndPlot();
                                pe.EndPlot(null);
                    else
                        ed_org.WriteMessage(
                          "\nAnother plot is in progress."
                HostApplicationServices.WorkingDatabase = db_org;
         * Get the Canonical Media Name
        private static string LocalToCanonicalMediaName(string localMediaName, PlotSettings acPlSet, PlotSettingsValidator acPlSetVdr)
            int cnt = 0;
            foreach (string CanonicalMediaName in acPlSetVdr.GetCanonicalMediaNameList(acPlSet))
                string localName = acPlSetVdr.GetLocaleMediaName(acPlSet, cnt);
                if (string.Equals(localMediaName, localName))
                    return CanonicalMediaName;
                cnt++;
            return null;
Replies (0)
