Line with Circle in between using overrule
alexisgacia
alexisgacia
I'm trying to create a line with circle in the middle. When the user call the function, it will able to select the start point and end point that will draw a line and circle/rectangle as 1 object. Middle of the line is an object like circle/rectangle that user will able to adjust the size of that object using grip.
Please share the sample code to guide me with similar effect.
Thanks in advance
parikhnidi
I think it is an ObjectARX / ObjectDBX issue. You can create your own custom entities with specified grip behavior. The learning curve is fairly steep, since, you are write a code in C++ and accessing core classes of AutoCAD.
Nimish
