Line.Angle givng a different reading to AutoCAD lines properties
I have copied in objects from another drawing into my drawing and then used the following code to look at line angles based on user selection.
[CommandMethod("AddPlObjEvent", CommandFlags.Session)]
        public void AddPlObjEvent()
            var doc = app.DocumentManager.MdiActiveDocument;
            var ed = doc.Editor;
            Database db = doc.Database;
            Vector3d mat = ed.CurrentUserCoordinateSystem.Translation;
            using (var ads = doc.LockDocument())
                var pPtRes = doc.Editor.GetEntity("Select an object");
                using (Transaction acTrans = db.TransactionManager.StartTransaction())
                    // Open the Block table record for read
                    BlockTable acBlkTbl;
                    acBlkTbl = acTrans.GetObject(db.BlockTableId,
                                                    OpenMode.ForRead) as BlockTable;
                    // Open the Block table record Model space for write
                    BlockTableRecord acBlkTblRec;
                    acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace],
                                                    OpenMode.ForWrite) as BlockTableRecord;
                    // Open the active viewport
                    ViewportTableRecord acVportTblRec;
                    acVportTblRec = acTrans.GetObject(doc.Editor.ActiveViewportId,
                                                        OpenMode.ForWrite) as ViewportTableRecord;
                    Line exampeLine = acTrans.GetObject(pPtRes.ObjectId, OpenMode.ForWrite) as Line;
                    ed.WriteMessage("\nLine Angle is:" + Place_Cables.Nearby_Cables.radToDeg(exampeLine.Angle));
It returns the wrong angles; the image below shows the angles I expect and see in properties and then in the red box the angles my code returns. I think it has something to do with UCS to WCS but I am unsure on how to get  the copied objects ordinate system. If I draw a new line then I get the angles not in the red box. I would like to either:
-use the copied ordinate system to convert my new line angles to the copied objects ordinates
-convert all copied objects to my ordinate system.
_gile
Line.Angle always returns the angle in radians measured counterclockwise from WCS X axis.
if you want to reflect the current angular units and the ANGDIR and ANGBASE settings as does the property palette, just use the Converter.AngletoSring method.
ed.WriteMessage("\nLine Angle is: " + Converter.AngleToString(exampeLine.Angle));
Gilles Chanteau
GileCAD
GitHub
I am not sure how the forums would get along without you gile
