Layout import code fails in AutoCAD 2015
The following code for importing a layout from another drawing works fine except for in 2015. In 2015, I get an eSetFailed error and the layout does not get created. I would to get any help to get this code working in 2015 also.
Public Shared Sub CopyLayerFrom(ByVal lname As String)
       ' Check if the application is still initalizing.
       If Starting Then
           Exit Sub
       End If
       Try
           ' Get the active Document, Editor, and Database objects.
           Dim doc As Document = Core.Application.DocumentManager.MdiActiveDocument
           Dim ed As Editor = doc.Editor
           Dim thisDb As Database = HostApplicationServices.WorkingDatabase
           ' Lock our Active Database.
           Using docLock As DocumentLock = Core.Application.DocumentManager.MdiActiveDocument.LockDocument
               ' Start a Transaction with the "Standard DB"
               Using tr As Transaction = Db.TransactionManager.StartTransaction
                   ' Get our Layer Table from our ""Standard DB"" and double check the Layer exists.
                   Dim lt As LayerTable = CType(tr.GetObject(Db.LayerTableId, OpenMode.ForRead, False), LayerTable)
                   If lt.Has(lname) Then
                       ' Get our Layer as an object and make sure it isn't erased (this would cause AutoCAD to crash if we imported a deleted layer).
                       Dim ltr As LayerTableRecord = CType(tr.GetObject(lt(lname), OpenMode.ForRead), LayerTableRecord)
                       If Not ltr.IsErased Then
                           ' Start a transaction with the Active Database
                           Using thisTr As Transaction = thisDb.TransactionManager.StartTransaction
                               Dim thisLt As LayerTable = CType(thisTr.GetObject(thisDb.LayerTableId, OpenMode.ForWrite), LayerTable)
                               If thisLt.Has(lname) Then
                                   ' Clone the Layer
                                   Dim map As New IdMapping()
                                   Dim objIDs As ObjectIdCollection = New ObjectIdCollection
                                   objIDs.Add(ltr.ObjectId)
                                   thisDb.WblockCloneObjects(objIDs, thisLt.ObjectId, map, DuplicateRecordCloning.Ignore, False'no defer
                                   thisTr.Commit()
                               Else
                                   ' Clone the Layer
                                   thisDb.WblockCloneObjects(objIDs, thisLt.ObjectId, map, DuplicateRecordCloning.Replace, False'no defer
                                   thisTr.Commit()
                               End If
                               thisDb.Clayer = thisLt(lname)
                           End Using
                           tr.Commit()
                       End If
                   End If
               End Using
           End Using
       Catch ex As Autodesk.AutoCAD.Runtime.Exception
           MsgBox(ex.Message + vbCrLf + vbCrLf + ex.ToString)
       End Try
   End Sub
Your code is for copying a layer between two AutoCAD databases. It is not for importing layouts.
Oops...wrong code...Here is the layout code...
Public Shared Sub CopyLayoutFrom(ByVal name As String)
      Try
          ' Get the active Document and Database, Lock the document and start a transaction with it.
          Dim activeDb As Database = doc.Database
          Using docLock As DocumentLock = doc.LockDocument()
              Using tr As Transaction = activeDb.TransactionManager.StartTransaction()
                  ' Start a Transaction with our Database and get the DBDictionary from its LayoutDictionary.
                  Using tr2 As Transaction = Db.TransactionManager.StartTransaction()
                      Dim dbob As DBObject = Db.LayoutDictionaryId.GetObject(OpenMode.ForRead)
                      Dim d As DBDictionary = CType(dbob, DBDictionary)
                      ' Get the active LayoutDictionary
                      Dim dbobActive As DBObject = activeDb.LayoutDictionaryId.GetObject(OpenMode.ForRead)
                      Dim dActive As DBDictionary = CType(dbobActive, DBDictionary)
                      ' Get the current Layout Manager being used by AutoCAD
                      Dim manager As LayoutManager = LayoutManager.Current
                      If dActive.Contains(name) Then
                          manager.CurrentLayout = name
                      Else
                          If d.Contains(name) Then
                              ' Get Layout and all of its IDs
                              Dim objIDs As New ObjectIdCollection()
                              Dim stdLayout As Layout = CType(d.GetAt(name).GetObject(OpenMode.ForWrite), Layout)
                              Dim stdLayBtr As BlockTableRecord = stdLayout.BlockTableRecordId.GetObject(OpenMode.ForRead)
                              For Each objectId As ObjectId In stdLayBtr
                                  objIDs.Add(objectId)
                              Next
                              ' Create a new Layout and clone over the base properties from the stdLayout
                              Dim newLayout As Layout = manager.CreateLayout(name).GetObject(OpenMode.ForWrite)
                              newLayout.CopyFrom(stdLayout)
                              ' Clone in our IDs
                              activeDb.WblockCloneObjects(objIDs, newLayout.BlockTableRecordId, New IdMapping(), DuplicateRecordCloning.Replace, False)
                              ' Regen the UI and set the Layout as current.
                              doc.Editor.Regen()
                          Else
                              Exit Sub
                          End If
                      End If
                      tr2.Commit()
                      tr.Commit()
                  End Using
              End Using
          End Using
      Catch ex As Exception
          MsgBox(ex.Message)
      End Try
  End Sub
moogalm
Autodesk Support
Autodesk Support
Hi gjmanuel,
Can you please verify with our .NET sample at Import a layout from an external drawing
I have checked it is working on 2015, do let me know if you still have problem.
ADN Support,
The .NET sample at Import a layout from an external drawing does solve the issue. I did have to add the following line to avoid a access denied error...besides that...it now works in 2015...thanks!
Using docLock As DocumentLock = acDoc.LockDocument()
Gary
