.LAS File format
.LAS File format
.LAS File format
Where I can find the description of the *.LAS file format.
I mean the file format used to store the state of the layers used by the export/import buttons of the layer state manager.
I need it to be able to mix layer states
GTVic
The format is similar (or maybe identical) to DXF file format. So if you look that up you should have a good idea.
There is a lot of reference material on the web for DXF.
Some people have reported issues editing LAS files, I was able to successfully edit using Notepad++, the file is stored in TEXT UTF-8 with BOM format, so using regular Notepad could have been the cause of reported issues.
