Jig multiple entity with user input
I am trying to copy a few blocks with jig, while jigging one block, with a keyword input it can change to a different block.
I did some research and probably EntityJig won't work, since it is specific to only one entity. It seems DrawJig is step-specific, other than that, can it accept user input to change to a different jig entity, please?
If I need to go to ObjectARX solution, please also advise me.
Thank you very much!
Norman_Yuan
Since showing code might be the better way to offer suggestions to your question, I have put together a working code example to address your question and published in my blog here, for better readability:
https://drive-cad-with-code.blogspot.com/2021/09/using-entityjig-with-keyword-options.html
Hope it help.
Norman Yuan
Drive CAD With Code
Seems not a straight answer to my 'block' situation but it solves the problem substantially when I thought it through...
Thank you very much, Norman!
