Jig and Orthomode
Jig and Orthomode
Jig and Orthomode
I'm jig a leader with an block in the end of the leader. When the orthomode is set to ON the leader not acquire the corret point. What effect have the UserInputControls.GovernedByOrthoMode?
Can anyone help me?
Thanls in advance.
Are you dragging a rubber-band cursor from a basepoint?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5815713@discussion.autodesk.com...
Can anyone help me?
Thanls in advance.
Sorry for my bad english.
Yes, the rubber-band is draggig always from the leader last vertice (basepoint) to the current cursor position.
I solved!
Thanks Tony, for the tips.
Hanauer, could you post the fix please?
Jeff
Here is the relevant code:
protected override SamplerStatus Sampler(JigPrompts prompts)
JigPromptPointOptions opt = new JigPromptPointOptions();
opt.UserInputControls =
(UserInputControls.Accept3dCoordinates
| UserInputControls.NoNegativeResponseAccepted
| UserInputControls.NullResponseAccepted);
if (m_leader == null)
opt.Message = "\nstart point: ";
else
// GovernedByOrthoMode is needed for orthomode
opt.UserInputControls |= UserInputControls.GovernedByOrthoMode;
opt.BasePoint = m_leader.VertexAt(m_leader.NumVertices);
// you can't use opt.UseBasePoint = true
// when ortho is on then not works
if (m_leader.IsSplined)
opt.SetMessageAndKeywords(
"\nSpecify Next point or [Line/Undo]: ",
"Line Undo");
else
"\nSpecify next point or [Spline/Undo]: ",
"Spline Undo");
PromptPointResult res = prompts.AcquirePoint(opt);
Thank you Hanauer
