- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I tried to modify the flip state properties of the dynamic block, but failed. Please give some ideas, thanks.
The code is below:
public enum DynBlockPropTypeCode
String = 1,
Real = 40,
Short = 70,
Long = 90
[CommandMethod("InsertDynBlock")]
public void InsertDynBlock()
Database db = HostApplicationServices.WorkingDatabase;
using (Transaction trans = db.TransactionManager.StartTransaction())
ObjectId model = db.GetModelSpaceId();
Dictionary<string, string> atts = new Dictionary<string, string>();
atts.Add("SYM.", "2");
atts.Add("WIDTH", "0.8m");
atts.Add("HEIGHT", "2m");
atts.Add("STYLE", "ONE PANEL");
atts.Add("REF#", "TS 1040");
atts.Add("MANUFACTURE", "TUR STYLE");
atts.Add("COST", "200.00");
ObjectId blockId = model.InsertBlockReference("Doors", "Door", Point3d.Origin, new Scale3d(), 0, atts);
blockId.SetDynBlockValue("Door Width", 0.8);
blockId.SetDynBlockValue("Flip vertical", 1);
trans.Commit();
public static void SetDynBlockValue(this ObjectId blockId, string propName, object value)
var props = blockId.GetDynProperties();
foreach (DynamicBlockReferenceProperty prop in props)
if (prop.ReadOnly == false && prop.PropertyName == propName)
switch (prop.PropertyTypeCode)
case (short)DynBlockPropTypeCode.Short:
prop.Value = Convert.ToInt16(value);
break;
case (short)DynBlockPropTypeCode.Long:
prop.Value = Convert.ToInt64(value);
break;
case (short)DynBlockPropTypeCode.Real:
prop.Value = Convert.ToDouble(value);
break;
default:
prop.Value = value;
break;
break;
