I have a .NET app that I wrote and pieced together from the internet. My app works in AutoCAD 2012 no problem. But we're moving to AutoCAD 2015 and I had to change the DLL files that are referenced to the 2015 files. Most of the app works fine.
The app checks the current Database if a certain block exists. If the block does exist, it reads all of the paperspace tabs and reads the titleblock in each tab and stores the drawing numbers, sheet numbers and titles from each. It then updates the attributes of a "Drawing List" block. If the block doesn't exist it inserts the block into the drawing where the user selected. And then updates the attributes as described above.
The function I use to insert the block and where the error is happening is:
Public Function InsertBlockReference(db As Database, blockName As String, insertPoint As Point3d, scale As Scale3d, angle As Double, layer As String, _ attValues As System.Collections.Hashtable) As ObjectId Using tr As Transaction = db.TransactionManager.StartTransaction() Dim bt As BlockTable = TryCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable) If Not bt.Has(blockName) Then Dim blockPath As String = HostApplicationServices.Current.FindFile(blockName & Convert.ToString(".dwg"), db, FindFileHint.[Default]) If String.IsNullOrEmpty(blockPath) Then Return ObjectId.Null End If bt.UpgradeOpen() Using tmpDb As New Database(False, True) tmpDb.ReadDwgFile(blockPath, FileShare.Read, True, Nothing) db.Insert(blockName, tmpDb, True) End Using End If Dim btr As BlockTableRecord = TryCast(tr.GetObject(bt(blockName), OpenMode.ForRead), BlockTableRecord) Using br As New BlockReference(insertPoint, btr.ObjectId) With {.ScaleFactors = scale, .Rotation = angle, .Layer = layer} Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor br.TransformBy(ed.CurrentUserCoordinateSystem) br.RecordGraphicsModified(True) If btr.Annotative = AnnotativeStates.[True] Then Dim contextCollection As ObjectContextCollection = db.ObjectContextManager.GetContextCollection("ACDB_ANNOTATIONSCALES") Autodesk.AutoCAD.Internal.ObjectContexts.AddContext(br, contextCollection.GetContext("1:1")) End If TryCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord).AppendEntity(br) For Each id As ObjectId In btr Dim aDef As AttributeDefinition = TryCast(tr.GetObject(id, OpenMode.ForRead), AttributeDefinition) If aDef IsNot Nothing Then Using aRef As New AttributeReference() aRef.SetAttributeFromBlock(aDef, br.BlockTransform) aRef.Position = aDef.Position + br.Position.GetAsVector() If attValues.ContainsKey(aDef.Tag.ToUpper()) Then aRef.TextString = attValues(aDef.Tag.ToUpper()).ToString() End If br.AttributeCollection.AppendAttribute(aRef) tr.AddNewlyCreatedDBObject(aRef, True) End Using End If Next tr.AddNewlyCreatedDBObject(br, True) tr.Commit() Return br.ObjectId End Using End Using End Function
I got the above Function from a forum online and I can't seem to find it again. I'll update if I can find it.
The line that seems to have the issue is:
And the error I'm receiving is:
Autodesk.AutoCAD.Runtime.Exception: eFilerError at Autodesk.AutoCAD.DatabaseServices.ImpHostApplicationServices.FindFile(String fileName, Database database, FindFileHint hint) at DrawingList.Class1.InsertBlockReference(Database db, String blockName, Point3d insertPoint, Scale3d scale, Double angle, String layer, Hashtable attValues) in \DrawingList - 2015\DrawingList\Class1.vb:line 541 at DrawingList.Class1.newDrawingList() in \DrawingList\Class1.vb:line 84 at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
And I can't seem to figure out why this is happening. Any help would be greatly appreciated.
