Insert block with attribute
bahman.jf.68
bahman.jf.68
hello everyone,
I wanted to insert a block which is exsiting on the drawing to a new point and updating attribitue defenetion.
BlockReference bref = new BlockReference(ptm, acBlkTbl["TestBlock"]);
                foreach (ObjectId attId in bref.AttributeCollection)
                    AttributeReference ar =
                        acTrans.GetObject(attId, OpenMode.ForRead) as AttributeReference;
                    if (ar != null && ar.Tag.ToUpper() == "WTYPE")
                        ar.UpgradeOpen();
                        ar.TextString = "SR23";
                        ar.DowngradeOpen();
                acBlkTblRec.AppendEntity(bref);
                acTrans.AddNewlyCreatedDBObject(bref, true);
                acTrans.Commit();
I didn't get any warning during the build, but does not appear any block at the point place.
_gile
When you create/insert a new block reference, you must explicitly Create the attribute references (AttributeReference) and add them to the block attribute collection (AttributeCollection). This is done by using the attribute definitions (AttributeDefinition) contained in the block definition (BlockTableRecord) as templates. See this topic of the docs.
// Add the block reference
// Add the attribute references
var blockDef = (BlockTableRecord)acTrans.GetObject(acBlkTbl["TestBlock"], OpenMode.ForRead);
foreach (ObjectId id in blockDef)
    if (id.ObjectClass == RXObject.GetClass(typeof(AttributeDefinition)))
        var attDef = (AttributeDefinition)acTrans.GetObject(id, OpenMode.ForRead);
        if (!attDef.Constant)
            var attRef = new AttributeReference();
            attRef.SetAttributeFromBlock(attDef, bref.BlockTransform);
            bref.AttributeCollection.AppendAttribute(attRef);
            acTrans.AddNewlyCreatedDBObject(attRef, true);
            if (attRef.Tag.ToUpper() == "WTYPE")
                attRef.TextString = "SR23";
acTrans.Commit();
Gilles Chanteau
GileCAD
GitHub
