How to iterate through object attributes?
Fairly new to C# .net so I am a bit lost with the flowchart below. I have blocks with custom attributes and I want to iterate through each object within the model space ( found in the blocktablerecord?) to find them. Then I want to access their attributes to look for the word "notes" within the Tags value. I found this tutorial on Extract Attribute info but I don't understand how AttributeCollection works. is it like the blocktablerecord that constains all entities?
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-NET/files/GUI...
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using Excel = Microsoft.Office.Interop.Excel;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.LayerManager;
using Autodesk.AutoCAD.Runtime;
using ACADapp = Autodesk.AutoCAD.ApplicationServices.Application;
using ATTCOL = Autodesk.AutoCAD.DatabaseServices.AttributeCollection;
namespace Get_Notes_v0._1
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void FindNotes_Click(object sender, EventArgs e)
            // Get the current document and database
            Document Doc = ACADapp.DocumentManager.MdiActiveDocument;
            Database DB = Doc.Database;
            Editor ED = Doc.Editor;
            // Start a transaction
            using (Transaction TRANS = DB.TransactionManager.StartTransaction())
                // Open the Block table for read
                BlockTable Btable = TRANS.GetObject(DB.BlockTableId, OpenMode.ForRead) as BlockTable;
                BlockTableRecord BTR = TRANS.GetObject(DB.BlockTableId, OpenMode.ForRead) as BlockTableRecord;
                //look at each objects attributes for key word note or notes
                foreach (ObjectId OBJID in BTR)
                    ATTCOL ATTREF = OBJID.GetObject(OBJID.Database, OpenMode.ForRead) as ATTCOL;
                        if (ATTREF.Tag == "CONST_REMARKS")
                            if (ATTREF.Value == "NOTE" || ATTREF.Value == "NOTES")
ActivistInvestor
Here is what your FindNotes_Click() handler should look like.
      Document Doc = Application.DocumentManager.MdiActiveDocument;
      Database db = Doc.Database;
      Editor ed = Doc.Editor;
      using(Transaction trans = db.TransactionManager.StartTransaction())
         ObjectId modelSpace = SymbolUtilityServices.GetBlockModelSpaceId(db);
         BlockTableRecord btr = trans.GetObject(modelSpace, OpenMode.ForRead) as BlockTableRecord;
         RXClass rxclass = RXClass.GetClass(typeof(BlockReference));
         foreach(ObjectId id in btr)
            if(id.ObjectClass.IsDerivedFrom(rxclass))
               BlockReference blkref = (BlockReference) trans.GetObject(id, OpenMode.ForRead);
               AttributeCollection attributes = blkref.AttributeCollection;
               foreach(ObjectId attId in attributes)
                  AttributeReference attref = (AttributeReference) trans.GetObject(attId, OpenMode.ForRead);
                  if(attref.Tag == "CONST_REMARKS")
                     if(attref.TextString == "NOTE" || attref.TextString == "NOTES")
                        // Or do something else with it.
                        ed.WriteMessage("\nFound attribute {0} = {1}", attref.Tag, attref.TextString);
            trans.Commit();
Visit the resources >here< for more help and examples on using the .NET API.
Also, it is customary to not use all CAPS for identifiers/varaibles in C#.
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-NET/files/GUID-BA69D85A-2AED-43C2-B5B7-73022B5F28F8-htm.html
using System;
using System.Data;
using System.Linq;
using System.Text;
        public Form1()
