How to get the MText position of a Dimension, it's not the textposition.
swaywood
swaywood
hi:
   I want to get the dimension text position of a dimension, it may be a RotatedDimension,AlignedDimension or other type of dimension.
   I tried to get the textposition, but it's not exactly the text postion.
   Could anyone tell me how to get it, or how to get the MText object?
regards
swaywood
SENL1362
               var peo = new PromptEntityOptions("Select Dimension");
                var per = ed.GetEntity(peo);
                if (per.Status != PromptStatus.OK)
                    return;
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    var dim = tr.GetObject(per.ObjectId, OpenMode.ForRead) as Dimension;
                    if (dim == null)
                        throw new System.Exception("Selected object is not a dimension");
                    var dimBlk = tr.GetObject(dim.DimBlockId, OpenMode.ForRead) as BlockTableRecord;
                    foreach(var id in dimBlk)
                        if (id.ObjectClass.DxfName=="MTEXT")
                            var mt = tr.GetObject(id, OpenMode.ForRead) as MText;
                            ed.WriteMessage("\n Dim Text:");
ed.WriteMessage("\n\t Block: {0}", dimBlk.Name); ed.WriteMessage("\n\t Text: {0}", mt.Contents); ed.WriteMessage("\n\t Position: {0}, {1}", mt.Location.X, mt.Location.Y); ed.WriteMessage("\n\t AttachmentPoint: {0}",Enum.GetName(typeof(AttachmentPoint), mt.Attachment)); ed.WriteMessage("\n\t Rotation: {0}", mt.Rotation * 180 / Math.PI); ed.WriteMessage("\n\t Width, Height: {0}, {1}", mt.ActualHeight, mt.ActualWidth); } } tr.Commit(); }
SENL1362
When you are interested in the frame around the Dimension Text, add this to the code:
[CommandMethod("MtFromDim")]
        public static void MtextFromDimension()
            Document doc = null;
            Database db = null;
            Editor ed = null;
            try
                doc = AcadApp.DocumentManager.MdiActiveDocument;
                if (doc == null)
                    throw new System.Exception("No MdiActiveDocument");
                db = doc.Database;
                ed = doc.Editor;
                    return;
                    if (dim == null)
                            var mtAngle = mt.Rotation;
                            var mtPos = mt.Location;
                            mt.UpgradeOpen();
                            mt.TransformBy(Matrix3d.Rotation(-mtAngle, Vector3d.ZAxis, mtPos));
                            var mtBounds = mt.GetBoundingPoints();
                            mt.TransformBy(Matrix3d.Rotation(mtAngle, Vector3d.ZAxis, mtPos));
                            for (int i = 0; i < mtBounds.Count; i++)
                                mtBounds[i]=mtBounds[i].TransformBy(Matrix3d.Rotation(mtAngle, Vector3d.ZAxis, mtPos));
                            ed.WriteMessage("\n\t Lower Left: ({0}, {1})", mtBounds[2].X, mtBounds[2].Y);
                            ed.WriteMessage("\n\t Lower Right: ({0}, {1})", mtBounds[3].X, mtBounds[3].Y);
                            ed.WriteMessage("\n\t Upper Right: ({0}, {1})", mtBounds[1].X, mtBounds[1].Y);
                            ed.WriteMessage("\n\t Upper Left: ({0}, {1})", mtBounds[0].X, mtBounds[0].Y);
var pl = new Polyline(); pl.AddVertexAt(0, new Point2d(mtBounds[2].X, mtBounds[2].Y), 0, 0, 0); pl.AddVertexAt(1, new Point2d(mtBounds[3].X, mtBounds[3].Y), 0, 0, 0); pl.AddVertexAt(2, new Point2d(mtBounds[1].X, mtBounds[1].Y), 0, 0, 0); pl.AddVertexAt(3, new Point2d(mtBounds[0].X, mtBounds[0].Y), 0, 0, 0); pl.Closed = true; pl.LayerId = mt.LayerId; var ms = (BlockTableRecord)tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForWrite); ms.AppendEntity(pl); tr.AddNewlyCreatedDBObject(pl, true); } } tr.Commit(); } } catch (System.Exception ex) { if (ed != null) ed.WriteMessage("\n Error in MtextFromDimension: {0}", ex.Message); } }
swaywood
Hi senl1362:
   Thank you so much~
   That's really help.
swaywood
