Ok... i am Very new to .net but i have written a little bit of lisp. SO what i want to do is Create a layer
called C-WATR-PIPE-6IN~ if it does not exist. this i figured out and is in the Code
Then if that layer Exist i want it to create C-WATR-PIPE-6IN~-SUP1 Again its in the Code below but how do i get it to automatically
go to the next number as in C-WATR-PIPE-6IN~-SUP2 i've tried everything i can think of but i get an error that object already exist so its still reading
the Sup 1 i just want it to keep adding Layers Sith the Sup1, 2, 3, Etc each time i run the command
See Code Below
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Colors
Imports Autodesk.AutoCAD.DatabaseServices
Public Class SupLyr
<CommandMethod("SupLyrs")>
Public Sub SupLyrs()
'' Get The Current Document and Database
Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
Dim acCurDb As Database = acDoc.Database
'' Start a Transaction
Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
'' Open the Layer Table for Read
Dim acLyrTbl As LayerTable
acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId,
OpenMode.ForRead)
Dim HALayerName As String = "C-WATR-PIPE-6IN~"
Dim sLayerSup As String = "-SUP"
Dim NSup As Integer = 0
If acLyrTbl.Has(HALayerName) = False Then
Using acLyrTblRec As LayerTableRecord = New LayerTableRecord()
'' assign the Layer a Name
acLyrTblRec.Name = HALayerName
'' Assign the Layer a Color
acLyrTblRec.Color = Color.FromColorIndex(ColorMethod.ByAci, 130)
'' Upgrade the Layer table for write
acLyrTbl.UpgradeOpen()
'' Append the new layer to the Layer table and the transaction
acLyrTbl.Add(acLyrTblRec)
acTrans.AddNewlyCreatedDBObject(acLyrTblRec, True)
End Using
End If
If acLyrTbl.Has(HALayerName) = True Then
acLyrTblRec.Name = HALayerName + sLayerSup & NSup
'' Save the changes and dispose of the transaction
acTrans.Commit()
End Using
End If
End Using
End Sub
End Class
Solved by _gile. Go to Solution.
Solved by Keith.Brown. Go to Solution.
This is off the top of my head but it should work. Its pseudo code but basically start with your base name and add an index to it until the layer table no longer has that name. The trick is to keep the original name untouched to use as a base point.
layerName = "C-WATR-PIPE-6"
tempName = layerName index = 1 While Not acLyrTble.Has(tempName)
tempName = layerName + index index++ End While
database.CreateLayer(tempName)
And where in my Code would i put that Code?
Oh Sorry this is for Civil 3D 2017
Here is a complete method that is working. Note that there was an issue with my pseudo code. I had While Not blah blah blah and it should have been while blah blah blah
C#
[CommandMethod("CreateLayerTest")] public void CreateLayerTest() { Document doc = Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; using (Transaction tr = db.TransactionManager.StartTransaction()) { LayerTable lt = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead); string layerName = "C-WATR-PIPE-6IN"; string tempName = layerName; int index = 1; while (lt.Has(tempName)) { tempName = layerName + "-SUP" + index; index++; } if (index != 1) { layerName = layerName + "-SUP" + (index - 1); } LayerTableRecord ltr = new LayerTableRecord(); ltr.Name = layerName; ltr.Color = Color.FromColorIndex(ColorMethod.ByAci, 130); lt.UpgradeOpen(); lt.Add(ltr); tr.AddNewlyCreatedDBObject(ltr, true); tr.Commit(); } }
VB
<CommandMethod("CreateLayerTest")> _ Public Sub CreateLayerTest() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Using tr As Transaction = db.TransactionManager.StartTransaction() Dim lt As LayerTable = DirectCast(tr.GetObject(db.LayerTableId, OpenMode.ForRead), LayerTable) Dim layerName As String = "C-WATR-PIPE-6IN" Dim tempName As String = layerName Dim index As Integer = 1 While lt.Has(tempName) tempName = layerName + "-SUP" + index index += 1 End While If index <> 1 Then layerName = layerName + "-SUP" + (index - 1) End If Dim ltr As New LayerTableRecord() ltr.Name = layerName ltr.Color = Color.FromColorIndex(ColorMethod.ByAci, 130) lt.UpgradeOpen() lt.Add(ltr) tr.AddNewlyCreatedDBObject(ltr, True) tr.Commit() End Using End Sub
It should not matter whether or not you are in regular autocad or a vertical like Civil3d. The code should work in all.
Thanks i will see what i can work up here with this..
i'll be back
OK... it Created the first layer ok... but when i run it again i get the following error
I copied your Text Exactly.. what did i do wrong... no errors in the Build
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.InvalidCastException: Conversion from string "C-WATR-PIPE-6IN-SUP" to type 'Double' is not valid. ---> System.FormatException: Input string was not in a correct format.
at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat)
at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value, NumberFormatInfo NumberFormat)
--- End of inner exception stack trace ---
at Lab1.CreateLayerTest.CreateLayerTest() in C:\Codes\Lab1-RDS\Lab1-RDS\Class5.vb:line 19
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.6.1637.0 built by: NETFXREL3STAGE
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 21.0.0.0
Win32 Version: 21.0.301.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcdbMgd.DLL
adui21
Assembly Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/adui21.DLL
AdUiPalettes
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdUiPalettes.DLL
WindowsBase
Win32 Version: 4.6.1638.0 built by: NETFXREL3STAGE
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
AdApplicationFrame
Win32 Version: 2015.11.2.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdApplicationFrame.DLL
AdWindows
Assembly Version: 2016.5.0.0
Win32 Version: 2016.5.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdWindows.DLL
System.Configuration
Win32 Version: 4.6.1586.0 built by: NETFXREL2
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
WindowsFormsIntegration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
PresentationFramework.Aero2
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/accoremgd.DLL
Acmgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Acmgd.DLL
AcWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.DLL
AcWindows.resources
Win32 Version: 21.0.212.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcWindows.resources.DLL
AcCui
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCui.DLL
PresentationFramework-SystemXml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
AeccUiWindows
Assembly Version: 11.0.771.0
Win32 Version: 11.0.771.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/AeccUiWindows.dll
AeccUiWindows.resources
Assembly Version: 11.0.659.0
Win32 Version: 11.0.659.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/en-US/AeccUiWindows.resources.DLL
System.Windows.Forms
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationUI
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
PresentationFramework-SystemXmlLinq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
AcSeamless
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcSeamless.DLL
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
AcSeamless.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcSeamless.resources.DLL
AmbercoreEngine
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AmbercoreEngine.DLL
AmberCore.IsdCodecAPI.Core
Assembly Version: 5.0.0.343
Win32 Version: 5.0.0.343
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AmberCore.IsdCodecAPI.Core.DLL
AecMgdReverse
Assembly Version: 7.9.48.0
Win32 Version: 7.9.48.0
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/aca/aecmgdreverse.dll
AecRibbon
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/ACA/AecRibbon.dll
AecGuiInterop
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/ACA/AecGuiInterop.DLL
AcMapResourceManagement
Assembly Version: 20.0.200.3
Win32 Version: 20.0.200.3
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/map/AcMapResourceManagement.dll
AcMapLoader
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/map/acmaploader.arx
ConvertText
CodeBase: file:///C:/program%20files/autodesk/autocad%202017/map/ConvertText.dll
OSGeo.MapGuide.PlatformBase
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
CodeBase: file:///C:/program%20files/autodesk/autocad%202017/map/OSGeo.MapGuide.PlatformBase.DLL
OSGeo.MapGuide.Foundation
CodeBase: file:///C:/program%20files/autodesk/autocad%202017/map/OSGeo.MapGuide.Foundation.DLL
Autodesk.Map.Platform
CodeBase: file:///C:/program%20files/autodesk/autocad%202017/map/Autodesk.Map.Platform.DLL
MapPublishImp
CodeBase: file:///C:/program%20files/autodesk/autocad%202017/map/MapPublishImp.DLL
Autodesk.MapGuide.Studio.Site
Assembly Version: 2.2.0.1
Win32 Version: 2.2.0.1
CodeBase: file:///C:/program%20files/autodesk/autocad%202017/map/Autodesk.MapGuide.Studio.Site.DLL
AcMapFeatureEntityTooltipsManager
CodeBase: file:///C:/program%20files/autodesk/autocad%202017/map/AcMapFeatureEntityTooltipsManager.dll
ResourceManagerRdfImp
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Map/ResourceManagerRdfImp.dll
System.Data
Win32 Version: 4.6.1636.0 built by: NETFXREL3STAGE
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
PresentationFramework-SystemData
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
AREXC3DStartX64
Assembly Version: 2017.0.1.3897
Win32 Version: 2017.0.1.3897
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202017/Products/Civil3D/AREXC3DStartX64.dll
Autodesk.REX.Framework
Assembly Version: 2017.0.0.0
Win32 Version: 2017.0.0.3866
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Autodesk.REX.Framework/v4.0_2017.0.0.0__51e16e3b26b42eda/Autodesk.REX.Framework.dll
Autodesk.Common.AResourcesControl
Win32 Version: 2013.1.0.0
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Autodesk.Common.AResourcesControl/1.0.0.0__ff3304d4f320ee59/Autodesk.Common.AResourcesControl.dll
REX.Manager
Assembly Version: 2017.0.0.3866
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202017/Framework/Engine/REX.Manager.dll
Autodesk.AutoCAD.Interop
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Autodesk.AutoCAD.Interop.DLL
Autodesk.AutoCAD.Interop.Common
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Autodesk.AutoCAD.Interop.Common.DLL
Autodesk.AECC.Interop.UiLand
Assembly Version: 11.0.0.0
Win32 Version: 11,0,659,0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/Autodesk.AECC.Interop.UiLand.dll
Autodesk.AEC.Interop.UIBase
Assembly Version: 7.9.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/ACA/Autodesk.AEC.Interop.UIBase.dll
Autodesk.AECC.Interop.Land
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/Autodesk.AECC.Interop.Land.dll
AREXC3DMngr
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202017/Products/Civil3D/AREXC3DMngr.dll
REX.Engine
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202017/Framework/Engine/REX.Engine.dll
REX.Preferences
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202017/Framework/Engine/REX.Preferences.DLL
REX.System
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202017/Framework/Engine/REX.System.DLL
REX.UI.Forms
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202017/Framework/Engine/REX.UI.Forms.DLL
REX.UI
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202017/Framework/Engine/REX.UI.DLL
REX.UI.WPF
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202017/Framework/Engine/REX.UI.WPF.DLL
REX.UI.resources
Assembly Version: 2017.0.0.3871
Win32 Version: 2017.0.0.3871
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202017/Framework/Engine/en-US/REX.UI.resources.DLL
REX.Foundation
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202017/Framework/Foundation/REX.Foundation.dll
REX.System.resources
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202017/Framework/Engine/en-US/REX.System.resources.dll
AREXC3DStartX64.resources
Assembly Version: 2017.0.0.3896
Win32 Version: 2017.0.0.3896
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202017/Products/Civil3D/en-US/AREXC3DStartX64.resources.dll
AcCustomize
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCustomize.DLL
AcCustomize.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCustomize.resources.DLL
atrc210_ARX
Win32 Version: 17, 1, 1784, 0
CodeBase: file:///C:/program%20files/autodesk/autodesk%20vehicle%20tracking%202017/atrc210_arx.dll
atrc210_CRX
CodeBase: file:///C:/program%20files/autodesk/autodesk%20vehicle%20tracking%202017/atrc210_crx.dll
EmbeddedSQLiteLoader
Win32 Version:
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/EmbeddedSQLiteLoader.dll
AcMapInfoCenter
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Map/AcMapInfoCenter.dll
AeccPartPublishingWizard
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/AeccPartPublishingWizard.dll
RiverRibbon140
Assembly Version: 14.1.1.1
Win32 Version: 14.1.1.1
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/Autodesk%20RiverRibbon.bundle/Contents/RiverRibbon140.dll
BIM360GlueAutoCAD2017Addin
Assembly Version: 4.37.6853.0
Win32 Version: 4.37.6853.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/BIM360GlueAutoCAD2017Addin.dll
BIM360GlueAddinsCommon
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/BIM360GlueAddinsCommon.DLL
log4net
Assembly Version: 1.2.11.0
Win32 Version: 1.2.11.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/log4net.DLL
CivilView.v1
Assembly Version: 2016.0.0.0
Win32 Version: 2016.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/CivilView.v1.dll
CVE.Data.Civil.v1
Assembly Version: 2014.0.0.0
Win32 Version: 2014.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/CVE.Data.Civil.v1.DLL
Ignytion.Core.v1
Assembly Version: 1.0.10078.134
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/Ignytion.Core.v1.DLL
FeaturedAppsPlugin
Win32 Version: 21.0.46.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps.bundle/Contents/Windows/2017/Win64/FeaturedAppsPlugin.dll
C3DVSP3D
Assembly Version: 3.3.0.0
Win32 Version: 2016.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/C3DVSP3D.dll
PresentationFramework-SystemCore
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Anonymously Hosted DynamicMethods Assembly
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
UIAutomationTypes
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
ContextualTabSelectorRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.dll
AeccUiMgd
Win32 Version: 11,0,771,0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/AeccUiMgd.DLL
AeccPressurePipesMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/AeccPressurePipesMgd.DLL
AcMapRibbonWrapper
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Map/AcMapRibbonWrapper.dll
AcMapRibbon
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Map/AcMapRibbon.dll
AeccContextTabRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/AeccContextTabRules.dll
AeccWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/AeccWindows.DLL
AeccDbMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/AeccDbMgd.DLL
Microsoft.Expression.Interactions
Win32 Version: 2.0.20520.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Microsoft.Expression.Interactions.DLL
ManagedMC3
Assembly Version: 9.1.0.7
Win32 Version: 9.1.0.7
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/ManagedMC3.DLL
AcLayer
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcLayer.resources.DLL
AecLayerManagerEx
CodeBase: file:///C:/program%20files/autodesk/autocad%202017/aca/AecLayerManagerEx.dll
UIAutomationProvider
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
AcAeNet.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcAeNet.resources.DLL
AcCloudRender.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCloudRender.resources.DLL
AcDxWizard.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcDxWizard.resources.DLL
AcExportLayoutUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcExportLayoutUI.resources.DLL
AcInterfere.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcInterfere.resources.DLL
AcLayerTools.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcLayerTools.resources.DLL
AcMrUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcMrUi.resources.DLL
AcMultiLineUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcMultiLineUi.resources.DLL
AcRecoverAll.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcRecoverAll.resources.DLL
AcScaleList.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcScaleList.resources.DLL
AcUnderlay.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcUnderlay.resources.DLL
AcViewTransitionsUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcViewTransitionsUi.resources.DLL
AdskConnectionPointMgd.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AdskConnectionPointMgd.resources.DLL
AcCalcUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCalcUi.resources.DLL
AcXrefUtil
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcXrefUtil.DLL
ClicJsInfoCenter
Win32 Version: 3.1.26.0
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/CLM/V3/MSVC14/ClicJsInfoCenter.dll
AecBaseMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AecBaseMgd.DLL
AcLivePreviewContext
PresentationFramework.Luna
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
AcMrUi
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcMrUI.DLL
Lab1-RDS
CodeBase: file:///C:/Codes/Lab1-RDS/Lab1-RDS/bin/Debug/Lab1-RDS.dll
FeaturedAppsPlugin.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps.bundle/Contents/Windows/2017/Win64/en-US/FeaturedAppsPlugin.resources.DLL
AcCommandToolTips
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCommandToolTips.DLL
AcCommandToolTips.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCommandToolTips.resources.DLL
VerticalTips
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Map/VerticalTips.dll
AeccUiTooltipContent
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/AeccUiTooltipContent.dll
AeccUiTooltipContent.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/C3D/en-US/AeccUiTooltipContent.resources.DLL
Assembly Version: 10.0.0.0
Win32 Version: 14.6.1586.0 built by: NETFXREL2
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
You do not need to paste the whole error message, just attentively read the ************** Exception Text ************** part.
It looks like you're trying to cast the string "C-WATR-PIPE-6IN-SUP" to double at line 19 of your code.
Sorry. I wrote the code in C# and converted it to VB for your use and made a small mistake. The issue is with using the + signs when concatenating strings. You can use the plus sign when you are concatenating only strings but once you add a non string then you need to use the ampersand. Or you can just use the .ToString() method on the index variable.
If small errors like this are giving you a problem then you should really try to learn more about .Net before programming autocad. It is a large leap without knowing the basics of .Net.
and how do i fix that??
as i said i am learning here
Updated VB Code with Ampersands instead of Plus signs for concatenating strings. Tested and working in AutoCAD.
<CommandMethod("CreateLayerTest")> _ Public Sub CreateLayerTest() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Using tr As Transaction = db.TransactionManager.StartTransaction() Dim lt As LayerTable = DirectCast(tr.GetObject(db.LayerTableId, OpenMode.ForRead), LayerTable) Dim layerName As String = "C-WATR-PIPE-6IN" Dim tempName As String = layerName Dim index As Integer = 1 While lt.Has(tempName) tempName = layerName & "-SUP" & index index += 1 End While If index <> 1 Then layerName = layerName & "-SUP" & (index - 1) End If Dim ltr As New LayerTableRecord() ltr.Name = layerName ltr.Color = Color.FromColorIndex(ColorMethod.ByAci, 130) lt.UpgradeOpen() lt.Add(ltr) tr.AddNewlyCreatedDBObject(ltr, True) tr.Commit() End Using End Sub
If you absolutely need to use/learn VB, replace the + operator which is also a concatenation operator in C#, with the VB concatenation operator: &.
As Keith said, you should first learn the .NET basics before trying to use the AutoCAD API which not so easy to learn.
That said, I'd add that if you just start learning .NET, learn C# instead of VB because you'll find much more help an good examples in C# than in VB.
Thanks guys.. i am doing my best here...
i have a book coming on .net and i also have the Autocad Platform Customization
and am searching the net recklessly...
i am gonna try to learn this and with help from guys like you i should be able to
