How to do a calculation by a formula line the evaluate method in EXCEL VBA?
swaywood
Message 1 of 18
swaywood
Hi:
I have a string like '(1-2+3)/4*5^2', How to calculate the fomula by some exist dll or class?
I found excel vba's evaluate function can do this, but does not work for every computer, I don't know the reason.
If you know other dll has this method, please tell me , thanks.
or you have other way to solve this?
  /// <summary>
  /// 利用Excel VBA Evaluate
  /// </summary>
  /// <param name="str"></param>
  /// <returns></returns>
  public static double Cal(this string str)
   string dllName = System.Reflection.Assembly.GetExecutingAssembly().Location.ToString();
   var app = new Excel.Application();
   FileInfo info = new FileInfo(dllName);
   Excel.Workbook workbook = app.Workbooks.Add(info.Directory.FullName + "\\Cal.xlt");
   Excel.Worksheet worksheet = workbook.Worksheets.Add() as Excel.Worksheet;
   var result = worksheet.Evaluate(str);
   app.DisplayAlerts = false;
   app.Quit();
   double data = double.Parse(result.ToString());
   return data;
Replies (17)
Message 2 of 18
_gile
You can try this:
        static double Calc(string expr)
            bool wasOpen = false;
            dynamic xlApp;
            try
                xlApp = Marshal.GetActiveObject("Excel.Application");
                wasOpen = true;
            catch
                try { xlApp = Activator.CreateInstance(Type.GetTypeFromProgID("Excel.Application")); }
                catch { throw; }
                var book = xlApp.Workbooks.Add();
                var sheet = book.ActiveSheet;
            try
                sheet.Cells[1, 1] = "=" + expr;
                return sheet.Cells[1, 1].Value;
            catch { return double.NaN; }
            finally
                book.Close(false);
                book = null;
                if (!wasOpen)
                    xlApp.Quit();
                    Marshal.ReleaseComObject(xlApp);
                    xlApp = null;
Gilles Chanteau
GileCAD
GitHub
Message 3 of 18
ActivistInvestor
If you don't want to have a dependence on Excel (which is not guaranteed to be installed on every computer your code runs on), you can use any number of open-source libraries for expression parsing and evaluation.
@swaywood wrote:
Hi:
  /// <summary>
  /// </summary>
   app.Quit();
   return data;
Message 4 of 18
swaywood
Hi @_gile:
dynamic can not be used in a framework 3.5 program?
microsoft csharp.dll's framework is 4.0+?
Message 5 of 18
_gile
@swaywood wrote:
Hi @_gile:
Yes the dynamic type came with the .NET Framework 4.0.
For prior Framework versions, to avoid referencing the COM libraries, you can use Late Binding with refelection.
        static object Calc(string expr)
            object xlApp;
            try
                wasOpen = true;
            catch
                catch { throw; }
            object books = xlApp.GetType().InvokeMember("Workbooks", BindingFlags.GetProperty, null, xlApp, null);
            object book = books.GetType().InvokeMember("Add", BindingFlags.InvokeMethod, null, books, null);
            object sheet = book.GetType().InvokeMember("ActiveSheet", BindingFlags.GetProperty, null, book, null);
            try
                object range = sheet.GetType().InvokeMember("Cells", BindingFlags.GetProperty, null, sheet, null);
                object cell = sheet.GetType().InvokeMember("Item", BindingFlags.GetProperty, null, range, new object[2] { 1, 1 });
                cell.GetType().InvokeMember("Value", BindingFlags.SetProperty, null, cell, new object[1] { "=" + expr });
                return (double)cell.GetType().InvokeMember("Value", BindingFlags.GetProperty, null, cell, null);
            catch
                return null;
            finally
                book.GetType().InvokeMember("Close", BindingFlags.InvokeMethod, null, book, new object[1] { false });
                book = null;
                if (!wasOpen)
                    xlApp.GetType().InvokeMember("Quit", BindingFlags.InvokeMethod, null, xlApp, null);
                    xlApp = null;
The .NET Framework 3.5 brings extension methods.
Using the following ones allows to avoid all the GetType().InvokeMember(...) stuff, and make the upper code more readable.
    public static class LateBindingextension
        public static object Get(this object obj, string propName, params object[] parameter) =>
            obj.GetType().InvokeMember(propName, BindingFlags.GetProperty, null, obj, parameter);
        public static void Set(this object obj, string propName, params object[] parameter) =>
            obj.GetType().InvokeMember(propName, BindingFlags.SetProperty, null, obj, parameter);
        public static object Invoke(this object obj, string methName, params object[] parameter) =>
            obj.GetType().InvokeMember(methName, BindingFlags.InvokeMethod, null, obj, parameter);
The code becomes:
            object xlApp;
            try
                wasOpen = true;
            catch
                catch { throw; }
            object book = xlApp.Get("Workbooks").Invoke("Add");
            object sheet = book.Get("ActiveSheet");
            try
                object cell = sheet.Get("Cells").Get("Item", 1, 1);
                cell.Set("Value", "=" + expr);
                return (double)cell.Get("Value");
            catch
                return null;
            finally
                book.Invoke("Close", false);
                book = null;
                if (!wasOpen)
                    xlApp.Invoke("Quit");
                    xlApp = null;
Gilles Chanteau
GileCAD
GitHub
Message 6 of 18
ActivistInvestor
Above I write that you could use a third-party library to evaluate math expressions.
Well, I'm not sure what I was thinking when I wrote that, but you don't need any third party library (or Excel) to do that.
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Internal.Calculator;
public static class CalcExample
   [CommandMethod("MYCALC")]
   public static void MyCalcCommand()
      var doc = Application.DocumentManager.MdiActiveDocument;
      var ed = doc.Editor;
      var pso = new PromptStringOptions("\nExpression: ");
      pso.AllowSpaces = true;
      var psr = ed.GetString(pso);
      if(psr.Status == PromptStatus.OK)
         try
            var result = Evaluate(psr.StringResult);
            ed.WriteMessage("\nResult: {0}", result);
         catch(System.Exception ex)
            ed.WriteMessage(ex.Message);
   public static double Evaluate(string expression)
      if(string.IsNullOrWhiteSpace(expression))
         throw new ArgumentException(nameof(expression));
      CalcEngine engine = CalcEngine.GetEngine();
      CalcValueType valueType = new CalcValueType();
      valueType.Type = ValueTypeEnum.RealType;
      CalcResult calcResult = new CalcResult(valueType);
      if(engine.EvaluateExpression(expression, null, calcResult))
         return calcResult.Result.R;
      throw new ArgumentException("Failed to evaluate expression: " + expression);
@swaywood wrote:
Hi:
  /// <summary>
  /// </summary>
   app.Quit();
   return data;
Message 7 of 18
_gile
@ActivistInvestor it seems to me CalcEngine is a third party library.
Anyway, form AutoCAD, we can use the geomcal.crx to evaluate arithmetic expressions (see >>here<< for expression reference)
        [CommandMethod("CALC")]
        public static void Calc()
            var ed = Application.DocumentManager.MdiActiveDocument.Editor;
            var pso = new PromptStringOptions("\nEnter the expression: ");
            if (psr.Status != PromptStatus.OK)
                return;
            if (result == null)
                ed.WriteMessage("\nInvalid expression");
            else
                ed.WriteMessage($"\nResult: {result}");
        public static object Evaluate (string expression)
            var linker = SystemObjects.DynamicLinker;
            if (linker.GetLoadedModules().IndexOf("geomcal.crx") == -1)
                linker.LoadModule("geomcal.crx", false, true);
            var args = new ResultBuffer(
                new TypedValue((int)LispDataType.Text, "c:cal"),
                new TypedValue((int)LispDataType.Text, expression));
            var result = Application.Invoke(args);
            return result?.AsArray()[0].Value;
Gilles Chanteau
GileCAD
GitHub
Message 8 of 18
SENL1362
ClearScript, Microsofts freeware product, is  my best of choice to add expressions to the C# program.
You can add simple expressions, but  also add you're own Objects to use in calculations.
This also adds C# functionality to PowerShell.
But it is supported from .NET 4.0 onwards
See below for a few MS samples.
https://microsoft.github.io/ClearScript/Tutorial/FAQtorial.html
And my ow usage
using Microsoft.ClearScript.Windows;
using (var vbScript = new VBScriptEngine())
var result = vbScript.Evaluate("(1-2+3)/4*5^2");
//ClearScript(VBScript) does not support IIF, therefore we supply this as a function
vbScript.Execute("Function IIf(bClause, sTrue, sFalse)\n If CBool(bClause) Then\n IIf = sTrue\n Else\n IIf = sFalse\n End If\n End Function");
vbScript.AddHostObject("propVals", requiredPropertyValues);
// now we can evaluate 'user formulars' like
//  Custom.Gemeente=discTek.Gemeente | planDoc.Custom.Plaats + iif(len(planDoc.Custom.Gemeente) > 0," gem. " & planDoc.Custom.Gemeente,"")
Message 9 of 18
_gile
With the geomcal, it would be more efficient to move the loading part to a static constructor or to the IExtensionApplication.Initialize() method.
Gilles Chanteau
GileCAD
GitHub
Message 10 of 18
_gile
using Autodesk.AutoCAD.DatabaseServices;
[assembly: CommandClass(typeof(AutoCAD2014Plugin.Commands))]
namespace AutoCAD2014Plugin
    public class Commands
        static Commands()
            SystemObjects.DynamicLinker.LoadModule("geomcal.crx", false, true);
                return;
            var result = TryEvaluate(psr.StringResult);
            if (result.HasValue)
                ed.WriteMessage($"\nType: {(LispDataType)result.Value.TypeCode} Value: {result.Value.Value}");
            else
        public static TypedValue? TryEvaluate(string expression) =>
            Application.Invoke(new ResultBuffer(
                new TypedValue((int)LispDataType.Text, expression)))?.AsArray()[0];
Gilles Chanteau
GileCAD
GitHub
Message 11 of 18
ActivistInvestor
@_gile, It seems to me that you're mistaken.
CalcEngine is what the Calculator UI and other components (like Data Extraction) depend on to access geomcal.arx.
It also implicitly loads geomcal.arx on first use.
Message 12 of 18
ActivistInvestor
ClearScript is an embedded scripting engine, not a mathematical expression engine.
Math expression engines don't support things like conditional branching, control flow/looping, etc.
It would be a bit of overkill for simply evaluating math expressions.
And my ow usage
Message 13 of 18
_gile
Sorry my mistake, i didn't see the Autodesk.AutoCAD.Internal.Calculator using directive.Smiley Embarassed
Gilles Chanteau
GileCAD
GitHub
Message 14 of 18
SENL1362
LOL, and then use Excel for simple arithmetrics.
You're absolutely right when only used for simple calculations, but in my experiences it didn't stop with that.
Sometimes the values aren't just numberes any more, but Legenda properties etc.
To support that i needed tools like grep, awk etc. Furtunately MS developed ClearScript for short dynamic expressions.
For more lengtly operations, like a bunch of convertion rules to apply on drawings, i convert the rules to c#, compile and run these progs. Al in just factions of seconds.
Message 15 of 18
ActivistInvestor
Using Excel for evaluating simple math expressions is definitely overkill, and probably the worst-possible way to solve that problem.
If the OP needs only to evaluate math expressions, AutoCAD has that ability without having to depend on additional libraries. AutoCAD's calculator engine also supports vector math, which ClearScript and most other general-purpose math expression engines don't support.
Message 16 of 18
ActivistInvestor
I neglected to mention that In the example code I posted above, angles are expressed as degrees rather than radians. The CAL command and the (cal) LISP function also express angles in degrees, and I'm not sure there's any way to change that.
But since that's considered non-standard for math expressions in general (e.g, System.Math, LISP, C/C++, etc.), the following revision of the Evaluate() method from the above code will interpret and return angles as radians rather than degrees. So, while the CAL command or (cal) lisp function returns 45.0 for the expression 'atan(1.0)', the revised Evaluate() method shown below will return pi/4.0:
   CalcContext context = new CalcContext();
   context.AngleUnits = AngleUnitsEnum.Radian;
   if(engine.EvaluateExpression(expression, context, calcResult))
Message 17 of 18
swaywood
Hi @ActivistInvestor
Thank you very much.
Do you have more help doc of CalcEngine?
I don't know how to write the 'string expression'.
In my case i will use '+,-,*,/,^(Power),Sqrt,Sqr,(),Pi'
best wishes
swaywood
Message 18 of 18
ActivistInvestor
best wishes
swaywood
The CalcEngine is what evaluates expressions for AutoCAD's calculator (CAL and QUICKCALC Commands).
You can see the docs for the calculator for the expression syntax, and keep in mind that the second version of the code I posted above uses radians rather than degrees (as the CAL and QUICKCALC command use).
With the second version of the Evaluate() method posted above,
These functions use radians in their argument:
sin(angle)
cos(angle)
tang(angle)
And, these functions return an angle in radians:
asin(real)
acos(real)
atan(real)
There is also another major difference between the CalcEngine and the (C:CAL) and (cal) LISP functions, which is in how integers are handled.
Using the (CAL) (or C:CAL) lisp function:
Command: (cal "50000+12000")
-3536
Using the CAL command:
Command: CAL
>> Expression: 50000+12000
62000
Using the MYCALC command from the example posted above:
Command: MYCALC
Result: 62000
Well, I guess they forgot to mention that. 8)
