How to define alias for autocad command using vb.net?
williamdepadua
Message 1 of 8
williamdepadua
Hi! I want to set shortcuts to my .Net commands. For sample:
My routine
<Autodesk.AutoCad.Runtime.CommandMethod("bomdia")>
Public Sub BomDia()
MsgBox("BomDia")
End Sub
Name command: bomdia
Alies command: bd
I know that it is possible to edit the acad.pgp file using FileSystem, but I wonder if there is any native or correct way to be done
Thank you
Replies (7)
Message 2 of 8
seabrahenrique
Hello!
I really don't know if is there another way to add an alias instead the acad.pgp edition (in my knowledge, okay?)
But a simple suggestion is to create another command method call the same function, you know?
For example:
Public Sub BomDia()
MsgBox("BomDia")
End Sub
<Autodesk.AutoCad.Runtime.CommandMethod("bd")>
Public Sub
Call BomDia
End sub
Got it?
Message 3 of 8
williamdepadua
Thanks for your reply, but I would like to allow the user to set their shortcuts through a custom interface. Without having to resort to acad.pgp
Message 4 of 8
seabrahenrique
Right.
If u want to make a interface to your user customize that shortcuts, inevitably you gonna make some "place" to save that preferences, agree? (like a txt file, the acad.pgp itself,  windows register.. etc).
(If not, the user will have to redo his shortcuts every time he starts AutoCAD)
Thinking that, another suggestion is to make a lisp file and attach to your application, and in that lisp file you can add some personalize shortcuts commands to call your .NET commands, you know? And then, you programming (with a filestream class) a interface to user changing this shortcuts and save in your lisp file....
But again: Maybe is there a more simple way to add shortcuts like a way that you want... but i really don't know and did not find here in a quick search... So, it's only a suggestion, and may another colleague here has a better one.
Message 5 of 8
williamdepadua
Liked! Thank you!
I'm just confused about this lisp file, when I have to save cofigurations, I use My.Settings which I believe is embedded in DLL.
I do not know how to work with lisp.
How do I do it?
Message 6 of 8
seabrahenrique
Do you have a .cuix file in your application? (I guess so, because is a very useful file)
So you simply can put your lisps here:
Here a tutorial to cuix files if you don't know yet.
Message 7 of 8
williamdepadua
Amazing!
I did the manual test and it worked perfectly
But I'm not able to load the lisp programmatically, I have a particular cuix and I want to carry the lisps for it.
My code:
Public Sub LoadLispToCuix(FileNameCuix As String, FileNameLisp As String)
Dim menuName As String = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("MENUNAME")
Dim maincs As Autodesk.AutoCAD.Customization.CustomizationSection = New Autodesk.AutoCAD.Customization.CustomizationSection(menuName + ".cuix")
Dim Cs As Customization.CustomizationSection
If maincs.PartialCuiFiles.Contains("PROCESS.cuix") = True Then
Cs = New Autodesk.AutoCAD.Customization.CustomizationSection("PROCESS.cuix")
Else
Try
LoadMyCui(FileNameCuix)
Catch ex As Exception
MsgBox("Não foi possível carregar o arquivo de costumização no caminho: " & vbCrLf & FileNameCuix)
Exit Sub
End Try
Cs.MenuGroup.LspFile(FileNameLsp) 'Not work
Cs.Save()
End Sub
Message 8 of 8
williamdepadua
I've been researching and it seems that someone has already come across this problema.
https://forums.autodesk.com/t5/net/add-to-the-cui-quot-lisp-files-quot-section-using-net/m-p/5029990...
That worked!
