How to create elliptical arc with two points and center point.
MarkJamesRogolino
MarkJamesRogolino
Hello, everyone. Now I wanna make a semi/quarter ellipse like following images, Hope to someone help me.
Ellipse should be lied crookedly. And I know 2 points of this ellipse. Thanks in advance.
hosneyalaa
Can you attached example drawing
MarkJamesRogolino
okay, you can find LEGENDS : table in this drawing.
hosneyalaa
@MarkJamesRogolino
SEE THIS
TRY
[CommandMethod("TEST")]
        public void Test()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            using (var tr = db.TransactionManager.StartTransaction())
                var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                Point3d cen = new Point3d(5156273.51 , -1187659.62 , 0 );
                Vector3d nor = Vector3d.ZAxis;
                Vector3d mAxis = new Vector3d(0.47 , -0.363 , 0);
                double rRatio = 0.2670;
                double stAng = -.66253;
                double enAng = 0.357;
                Ellipse ellipse = new Ellipse(cen, nor, mAxis, rRatio, stAng, enAng);
                curSpace.AppendEntity(ellipse);
                tr.AddNewlyCreatedDBObject(ellipse, true);
                tr.Commit();
MarkJamesRogolino
Thank you for your help. But can you find to make two ends of ellipse coincides to blue mark points?
MarkJamesRogolino
I don't know meaning of mAxis(third parameter). Could you tell me ? Thank you again.
hosneyalaa
Really I know a lot about ellipse
You can see this
https://help.autodesk.com/view/OARX/2022/ENU/?guid=OARX-ManagedRefGuide-Autodesk_AutoCAD_Geometry_El...
It is possible if @_gile  has the time to help you and he has sufficient experience
