How to Call Sharepoint via MS Graph, inside LispFunction?
CodeDing
CodeDing
Hey all,
I am very frustrated & flustered. I do not understand connecting to MS Graph at ALL.
Can someone PLEASE help me get a working example of reaching out to MS Graph via C#?
In my IDEAL scenario, my lisp function is passed a URL string that will call Sharepoint (JUST like the old Sharepoint API), and simply return the body/text returned by the URL call.
So this Parameter passed to the Lisp Function:
http://<site url>/_api/web/lists
Would return something like:
<?xml version="1.0" encoding="utf-8"?>
<feed xml:base="https://...../_api/"
    xmlns="http://www.w3.org/2005/Atom"
    xmlns:d="http://schemas.microsoft.com/ado/2007/08/dataservices"
    xmlns:m="http://schemas.microsoft.com/ado/2007/08/dataservices/metadata"
    xmlns:georss="http://www.georss.org/georss"
    xmlns:gml="http://www.opengis.net/gml">
    <id>.....</id>
    <title />
    <updated>2024-09-06T19:34:06Z</updated>
    <entry m:etag="&quot;0&quot;">
    </entry>
</feed>
Some info:
- I have a .NET Framework (4.7.2) project in Visual Studio
- I have registered an app via our company Azure account, so I have a TenantId and ClientID.
- I do NOT have a secret code generated from Azure, hopefully I do not need it?
- This DLL will ONLY be used within the company and by company employees on our internal computer systems.
- Users ALL have a company Microsoft account and can access the Sharepoint site (our company sharepoint site).
- I only want to perform READs from the Sharepoint site
- Whenever I run my code, I get this error:
could not load file or assembly azure.identity
If you could REALLY dumb your explanation down for me it would be greatly appreciated.
Here's my existing code:
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Microsoft.Graph;
using Azure.Identity;
namespace HCL
    public static class LispFunctions
        [LispFunction("hcl-microsoft-web-get")]
        public static async Task<ResultBuffer> MicrosoftWebGet(ResultBuffer rbIn)
            if (rbIn == null) return ErrorPrompt("\n(hcl-microsoft-web-get url) error: arguments expected");
            TypedValue[] args = rbIn.AsArray();
            if (args.Length > 1) return ErrorPrompt("\n(hcl-microsoft-web-get url) error: too many arguments");
            if (args[0].TypeCode != (int)LispDataType.Text) return ErrorPrompt("\n(hcl-microsoft-web-get url) url error: expected string");
            string url = (string)args[0].Value;
            var scopes = new[] { "User.Read" };
            // Multi-tenant apps can use "common",
            // single-tenant apps must use the tenant ID from the Azure portal
            var tenantId = "{myTenantId}";
            // Value from app registration
            var clientId = "{myClientId}";
            // using Azure.Identity;
            var options = new DeviceCodeCredentialOptions
                AuthorityHost = AzureAuthorityHosts.AzurePublicCloud,
                ClientId = clientId,
                TenantId = tenantId,
                // Callback function that receives the user prompt
                // Prompt contains the generated device code that user must
                // enter during the auth process in the browser
                DeviceCodeCallback = (code, cancellation) =>
                    Console.WriteLine(code.Message);
                    return Task.FromResult(0);
            // https://learn.microsoft.com/dotnet/api/azure.identity.devicecodecredential
            var deviceCodeCredential = new DeviceCodeCredential(options);
            var graphClient = new GraphServiceClient(deviceCodeCredential, scopes);
            var result = await graphClient.Sites["{my-company-site}"].Lists.GetAsync();
            // return result.??
            return null;
        private static ResultBuffer ErrorPrompt(string message)
            Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(message);
            return null;
Best,
~DD
Need AutoLisp help? Try my custom GPT 'AutoLISP Ace':
https://chat.openai.com/g/g-Zt0xFNpOH-autolisp-ace
Replies (0)
