.NET
How to call FLATSHOT entirely from .NET code?
8 REPLIES 8
Message 1 of 9
1353 Views, 8 Replies
Hello devs,
what is the .NET (C#) equivalent of FLATSHOT?
Does anyone have a code sample producing the following result?
1. Project a set of 3D models onto a 2D plane from an arbitrary point of view.
2. I need the projected result in "Hidden" visual style. (Hide overlaped lines)
(Just like in FLATSHOT, when "Display Hidden lines" is not chosen)
3. Save the projection as a block. (Explodable block, just like the result of a flatshot)
All of this entirely from code. No commands such as FLATSHOT, FLATTEN, etc..
Thanks for your time and effort, may the solution be helpful to everyone.
8 REPLIES 8
Message 2 of 9
R.Gerritsen4967
This may help:
https://www.theswamp.org/index.php?topic=42597.0
Basicaly what is says is that you need to create a section of a solid. Apparently the section's plane doesn't need to intersect the solid.
Never used this myself though....
Message 3 of 9
SEANT61
Native ObjectARX (C++) does have a Hidden Line Removal API (see . . . ObjectARX****-utils-HlrApi).
.NET compatible wrapper (AutoCAD 2019+) looks to be available through the steps described here:
Managed HLR API for AutoCAD - AutoCAD DevBlog (typepad.com)
I have a project that addresses the 3d to 2d hidden line functionality, and I, too, wished to stay within the Managed ARX confines (plus I need to stay <= AutoCAD 2016).
The endeavor was convoluted but I was able to use a virtual XPS printer setup and subsequent analysis of the file to recreate geometry - thus mimicking the desired functionality.
Though slower and more complex, this methodology allows for non Solid3d entities as well as Layer isolation.
See the 2DREN command in the screencasts in this thread (Note:  several different commands are demoed in the screencasts):
http://www.theswamp.org/index.php?topic=55526.0
May your cursor always snap to the location intended.
Message 4 of 9
in reply to: SEANT61
@SEANT61 Sounds good, I will try the C++ part out! Thank you for your contribution!
Message 5 of 9
insmuratturna
You can try  the Flatshot command with Ed.Command
ed.Command("_.FLATSHOT", h, "1", "1", "0");
Message 6 of 9
in reply to: insmuratturna
Does this actually work for you? Have you tried it yourself?
Message 7 of 9
insmuratturna
It is only one line command
Why dont you try
Message 8 of 9
@insmuratturna
I have tried, and there is not such a method "Command(...);"
You should try before suggesting
Message 9 of 9
norman.yuan
Editor.Command()/CommandAsync() is available since AutoCAD 2015. So, @insmuratturna 's suggestion is certainly valid. The difference of calling Editor.Command() and Document.SendTextToExecute() is that Editor.Command can only be called in Document context.
Norman Yuan
Drive CAD With Code
Autodesk Customer Advisory Groups
