.NET
How to arrange custom buttons in custom ribbon?
4 REPLIES 4
luckyboy82292
222 Views, 4 Replies
Hey there!
I have created a custom ribbon but now I need to arrange the buttons as I need but it doesn't fit well. So is there any way to fix the size and arrange it as we need. I want to arrange the buttons as shown in the below SS:
But mine look like this:
Edit:
I forgot to share the code, so here is the code:
private void CreateRibbon()
    try
        RibbonControl ribCntrl = Autodesk.AutoCAD.Ribbon.RibbonServices.RibbonPaletteSet.RibbonControl;
        if (ribCntrl == null) return;
        var existingTab = ribCntrl.Tabs.FirstOrDefault(t => t.Id == MY_TAB_ID);
        if (existingTab != null && existingTab.IsActive) return;
        if (existingTab != null)
            ribCntrl.Tabs.Remove(existingTab);
        RibbonTab ribTab = new RibbonTab { Title = "Advanced Tools", Id = MY_TAB_ID };
        ribCntrl.Tabs.Add(ribTab);
        AddSimplePanel(ribTab, "CAD Tools");
        if (wasActive)
            ribTab.IsActive = true;
        ribTab.Activated += RibTab_Activated;
        ribTab.Deactivated += RibTab_Deactivated;
    catch (Exception ex)
        Application.DocumentManager.MdiActiveDocument?.Editor.WriteMessage($"\nError creating ribbon tab: {ex.Message}");
private void AddSimplePanel(RibbonTab tab, string panelTitle)
    RibbonRowBreak rbrk = new RibbonRowBreak();
    RibbonSubPanelSource rspl = new RibbonSubPanelSource();
    RibbonPanelSource panelSource = new RibbonPanelSource { Title = panelTitle };
    RibbonPanel ribPanel = new RibbonPanel { Source = panelSource };
    tab.Panels.Add(ribPanel);
    RibbonRowPanel rowPanel = new RibbonRowPanel();
    panelSource.Items.Add(rowPanel);
    var buttons = new[]
        ("Command 1", "COMMAND1 "),
        ("Command 2", "COMMAND1 "),
        ("Command 3", "COMMAND1 "),
    int count = 0;
    int index = 0;
    foreach (var (text, command) in buttons)
        var button = new RibbonButton
            Text = text,
            ShowText = true,
            Orientation = System.Windows.Controls.Orientation.Horizontal,
            Size = RibbonItemSize.Standard,
            CommandParameter = command,
        button.CommandHandler = new RelayCommand();
        rowPanel.Items.Add(button);
4 REPLIES 4
norman.yuan
in reply to: luckyboy82292
You need to use RibbonRowBreak, RibbonRowPanel... properly. For example, if I want to have a Panel hold 9 command buttons in 3 rows, and each row with 3 buttons, I can have code as shown below:
using Autodesk.AutoCAD.Ribbon;
using Autodesk.Windows;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace AcadMicsTests
    public class MyRibbon
        private readonly RibbonControl _ribbonControl;
        private const string TAB_ID = "MY_CUSTOM_RIBBON_TAB";
        public MyRibbon()
            _ribbonControl = ComponentManager.Ribbon;
        public void CreateMyTab()
            if (_ribbonControl==null)
                throw new InvalidOperationException(
                    "Ribbon menu is not available.");
            if (_ribbonControl.FindTab(TAB_ID) != null) return;
            BuildTab();
        private void BuildTab()
            var tab=new RibbonTab();
            tab.Title = "My Custom Tab";
            tab.Id= TAB_ID;
            AddRibbonPanelToTab(tab);
            _ribbonControl.Tabs.Add(tab);
            _ribbonControl.ActiveTab = tab;
        private void AddRibbonPanelToTab(RibbonTab tab)
            var source = new RibbonPanelSource { Title = "Custom Commands", Id = "MY_CUSTOM_COMMANDS" };
            var panel = new RibbonPanel { Source = source };
            RibbonRowPanel rowPanel;
            rowPanel = CreateRibbonRowPanel(
                new []
                    new RibbonCommandButton{Text="Xxxxxx1", ShowText=true },
                    new RibbonCommandButton{Text="Xxxxxx2", ShowText=true },
                    new RibbonCommandButton{Text="Xxxxxx3", ShowText=true },
            source.Items.Add(rowPanel);
            source.Items.Add(new RibbonRowBreak());
                new []
                    new RibbonCommandButton{Text="Yyyyyy1", ShowText = true},
                    new RibbonCommandButton{Text="Yyyyyy2", ShowText=true },
                    new RibbonCommandButton{Text="Yyyyyy3", ShowText = true},
                new[]
                    new RibbonCommandButton{Text="Zzzzzz1", ShowText=true },
                    new RibbonCommandButton{Text="Zzzzzz2", ShowText=true },
                    new RibbonCommandButton{Text="Zzzzzz3", ShowText=true },
            tab.Panels.Add(panel);
        private RibbonRowPanel CreateRibbonRowPanel(IEnumerable<RibbonCommandButton> buttons)
            var rowPanel=new RibbonRowPanel();
            foreach (var btn in buttons)
                rowPanel.Items.Add(btn);
            return rowPanel;
        [CommandMethod("MyRibbonTab")]
        public static void AddMyCustomRibbonTab()
            try
                var myRibbon= new MyRibbon();
                myRibbon.CreateMyTab();
            catch (System.Exception ex)
                CadApp.ShowAlertDialog($"Error:\n{ex.Message}");
Here is the picture showing the created ribbon tab:
HTH
Norman Yuan
Drive CAD With Code
luckyboy82292
in reply to: norman.yuan
This worked but what I need is to set the property manually like Height, Width and position etc. But change in these properties doesn't effect at all.
Check out the official format for Autodesk Plugins (.bundle ).  You can build the UI for your custom tools right in CAD with the CUI command and use the .cuix file for your UI, keeping it separate from your C#.  Super convenient and easy to manage.  There's nice extras, like you can assign Extended Help File custom .xaml to the buttons (in the cuix file) for fancy dropdown tooltips on hover that can include images, etc.  It's pretty nice, really.
The ribbon only supports predefined button sizes, but not custom sizes, so setting the height and width properties of a RibbonItem will not work. That applies to both custom ribbon content you create and add yourself via code, as well as ribbon content created using the CUI.
AutoCAD Inside the Factory
