How to add Xdata to new create object?
Message 1 of 8
hi ,everyone . I create a new polyline and i want to add Xdata to polyline every point. how to do it?
Replies (7)
Message 2 of 8
_gile
This topic from the .NET Developer's Guide may help:
http://help.autodesk.com/view/ACD/2017/FRA/?guid=GUID-92D663FA-0452-44F4-BDAC-0EEF0AF3BD88
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
I can use these to add xdata to each point in polyline2d and polyline3d because the point is vertex2d or vertex3d:
Polyline3d Polylin;
foreach (ObjectId id in Polyline)
id.Xdata=Values;
but how to do it in polyline; when i use : foreach (ObjectId id in Polyline) it doesn't work.
Message 4 of 8
_gile
It looks like you're missing the AutoCAD .NET API basics.
You cannot add xdata to an ObjectId, you can only add xdata to DBObject (the base class for all graphic and non graphic database resident objects).
An ObjectId is an unique identifier which can be use to open the object itself (see this topic).
Assuming you create a new polyline (as said in the OP), for polyline 2d or 3d you have to create each vertex object.
You can add the xdata directly to the newly created vertex at this time.
Gilles Chanteau
GileCAD
GitHub
Message 5 of 8
Poyline2d polyline;
DBObject obj = id.GetObject(OpenMode.ForRead);
obj .Xdata=Values;
Like up, i can add xdata to point in polyline2d and polyline3d ,but my problem is can not add xdata to polyline. becase foreach (ObjectId id in Polyline) doesn't work when polyline is Polyline.
Message 6 of 8
_gile
Polyline (AKA Light Weigth Polyline, optimized polyline, LWPOLYLINE) is not a 'complex entity' (i.e. entities containing subentities).
Gilles Chanteau
GileCAD
GitHub
Message 7 of 8
you mean it is impossible to add xdata to point in polyline??
Message 8 of 8
Alexander.Rivilis
Yes. You can add xdata to whole Polyline, but can not add xdata to its vertexes because of vertexes are not objects/entities.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
