I use AutoCAD 2016 , and want to add a tool in picture location . 1. use PaletteSet , but when i dock top , this minHeight will bigger then i want so
has other interface or issues to show this?
if (PSet == null || PSet.Visible == false)
var window = new PatternSetWindow();
PSet = new PaletteSet("TYDI_Document");
PSet.Visible = true;
ElementHost host = new()
AutoSize = true,
Dock = DockStyle.Fill,
Child = window
PSet.Style = PaletteSetStyles.ShowCloseButton | PaletteSetStyles.ShowAutoHideButton | PaletteSetStyles.ShowPropertiesMenu | PaletteSetStyles.Notify ;
PSet.Add("TYDI_Document", host);
PSet.KeepFocus = true;
PSet.Size = new Size(1200, 30);
PSet.MinimumSize = new Size(1200, 3);
PSet.Dock = DockSides.Top;
PSet.DockEnabled = DockSides.Top;
//PSet.WindowState = Window.State.Minimized;
PSet.RecalculateDockSiteLayout();
LanHui Xu
Why do you want to use PaletteSet docked on top, instead of standard menu system (Ribbon, namely). You can create your own partial menu using command CUI and distribute/deploy it with your app/plugin together, which can be easily edited/updated. If you really want a dynamically created menu items with code, you can code your own Ribbon tab/panel/items... and load it with your plugin. If you really want to use PaletteSet that looks/works like ToolPaletteSet, then do not expect it can be docked like toolbar.
Hi @norman.yuan :
i try to use the toolbar to set commands , but designer want change the button image to text , like : "text align"
in paletteSet , is real- minValues is more than 100 piexls , even set the `MinimumSize` like : 30
also im try to show only text with cui or mns , but is failed , also has button , do you has the similar example or issue?
thanks.
LanHui Xu
Why not use ribbon button in Ribbon menu. which can have text caption with or without image?
Hi @norman.yuan :
in objectarx , i use the cAcuiDialog to show this style .
i want to get the same style use c# , beacuse the document web api and other servers api use c# will easy to connect , but try to use toolbar or PaletteSet that cant support .
LanHui Xu
