How to add a tooltip next to command C# API ?
traiduong014969
traiduong014969
Hi all,
Recently, I learned how to create a command in the ribbon and successfully implemented it. However, I have a question. By default, when I type a command, I notice that some commands display an icon and a tooltip when I drag mouse point them for a short time. I would like to achieve the same for my command. Can someone help me with this?
Thank you !
Jeff_M
Add a RibbonToolTip to the Button.
Jeff_M, also a frequent Swamper
traiduong014969
actually, I also use some properties on ribbon tooltip properties, but I don't know I only work in ribbon and not work in command that i type on the keyboard. You can see in this picture above.
I want to create the same on ribbon and also have icon. I tried with CUIx method, and it works, however when i with RUNTIME method, it does not work.
ToolTip = new RibbonToolTip()
    Title = "Support",
    Content = "ABC TEST",
    ExpandedContent = "ABC TEST",
    ExpandedImage = imgTooltip,
    Command = "V1",
    IsProgressive = true
ActivistInvestor
AutoCAD refers to these as Command Tooltips. You can look at this topic
