.NET
How do you find 'if' a polyline is inside another polyline?
2 REPLIES 2
jpkycek
675 Views, 2 Replies
2 REPLIES 2
StephenPreston
in reply to: jpkycek
Assuming coplanar polylines, this is one technique:
1. Convert the polyline to a region (Region.CreateFromCurves)
2. Intersect the regions (Region.BooleanOperation)
3. Compare the area of the resultant intersection with the area of the smaller region you created in 1.
4. If the areas are equal (within your required tolerance), then the smaller polyine was completely enclosed by the larger on.
Cheers,
Stephen Preston
Autodesk Developer Network
Cheers,
Stephen Preston
Discussion_Admin
If you are posting using IE 9 and the body of your post is blank. Please see the following thread in the Feedback & Questions about the Discussion Groups forum.
http://forums.autodesk.com/t5/Feedback-Questions-about-the/Blank-Posts-Known-IE9-issue/m-p/2962896/m...
Thanks for using the forums
Discussion_Admin
Forma Design Contest
