Hide part of polyline that across a block
kittichai.n
kittichai.n
I try to hide some part of polyline when it across a block. I used overrule to hide it but not success because the WorldDraw method not allow me to use Document doc = Application.DocumentManager.MdiActiveDocument;.
In the WorldDraw method, I wrote some code to select blocks that across the polyline and find the intersection between the polyline and blocks. so I need to use Editor.SelectFence() to select block object.
Have any ways to avoid this? Thanks in advances.
my code:
public override bool WorldDraw(Drawable drawable, WorldDraw wd)
GrxCAD.DatabaseServices.Polyline pl = drawable as GrxCAD.DatabaseServices.Polyline;
DBObject plobj = drawable as GrxCAD.DatabaseServices.DBObject;
Editor ed = doc.Editor;
if (_overruling)
// Get xdata
List<HiddenSegment> hs = ReadXDataHiddenSegment(plobj);
// Get polyline's vertices
Point3d[] pts = new Point3d[pl.NumberOfVertices];
for (int i = 0; i < pl.NumberOfVertices; i++)
pts[i] = pl.GetPoint3dAt(i);
// Draw each segments
int n = 0;
//Tolerance tol = new Tolerance(0.0001, 0.0001);
while (n < pts.Length)
if ((n + 1) < pts.Length)
// create fence to select
Point3dCollection fe = new Point3dCollection
pts[n],
pts[n + 1]
// select object that the segment was across
PromptSelectionResult PromptSel = ed.SelectFence(fe);
// if objects were found on the current segment.
if ((PromptSel.Status == PromptStatus.OK) && (PromptSel.Value.Count > 0))
SelectionSet sset = PromptSel.Value;
// get all intersection points between the segment and objects
foreach (SelectedObject selobj in sset)
// get the intersection points (between pline and object)
Point3dCollection interPt = EntityInters.GetIntersectionPointInAndOut(selobj.ObjectId, plobj.ObjectId);
if (interPt.Count == 2)
fe.Add(interPt[0]);
fe.Add(interPt[1]);
// sorting all points
Point3dCollection SortedFe = SortPoints.SortPoint3d(fe);
// draw
int i = 0;
while (i < pts.Length)
if ((i + 1) < pts.Length)
wd.Geometry.WorldLine(SortedFe[i], SortedFe[i + 1]);
i += 2;
} else
wd.Geometry.WorldLine(pts[n], pts[n + 1]);
n += 1;
return true;
else
return base.WorldDraw(drawable, wd);
norman.yuan
So, the issue you have is to identify entities (BlockReferences in your case) that intersect with the overruled Polyline. You should not use Editor.SelectFence/Window...() method, even you can MdiActiveDocument is reachable: these methods only works while the selecting fence/window is within current view, which cannot be certain when you overrule the polyline.
You can simply loop through the current space in which the polyline resides to test if a BlockReference intersects with it.
Norman Yuan
Drive CAD With Code
kittichai.n
Thanks very much for your helpful answer.
I have another question. Overrule does not refresh (regen) after I moved the block from the overrule polyline.
Should I have an editor reactor for the move command? or can I have another overrule for blocks?
