Help with move command (Math) :)
Hi, I know I'm missing something simple. I have sub that moves a cogo point label, (this is not civil 3d related) and there is something funny about my pick point. When I select the base point and then the second point the label moves just fine except it is slightly off from my second pick point. I know it has to do with the base point of the label but I cant for the life of me figure out the correct math to compensate for it. There are two images attached showing my base point pick and second pick. In the second pick image, where the cross-hairs are is where I picked for placement. (I am picking the middle of the zero, and expect the middle of the zero to be at my second point.) Any help would be appreciated.
P.S. I have tried getting the vector from the label base point to first pick point and compensating that into the equation but that did work. (Most likely did it wrong)
<CommandMethod("mcptlbmov")> Public Sub CogoPointLabelMove() 'Get the current document and editor Dim curDb As Database = Active.Database Dim docEd As Editor = Active.Editor Try 'Create a typedvalue array to define the filter criteria Dim acTypValAr(0) As TypedValue acTypValAr.SetValue(New TypedValue(DxfCode.Start, "AECC_COGO_POINT"), 0) 'Assign the filter criteria to a selectionfilter object Dim acSelFtr As New SelectionFilter(acTypValAr) 'Start cogo point selection prompt option Dim promptSelectionOptions As New PromptSelectionOptions promptSelectionOptions.MessageForAdding = (vbLf & "Select COGO Points Labels to move: ") 'Get prompt selection results Dim cogoPointPromptSelectionResult = docEd.GetSelection(promptSelectionOptions, acSelFtr) 'Set selection set Dim cogoPointSelectionSet As SelectionSet = cogoPointPromptSelectionResult.Value 'If selection are cogo points If cogoPointPromptSelectionResult.Status = PromptStatus.OK Then 'Start base point prompt point option Dim pointPromptOptions = New PromptPointOptions(vbLf & "Specify base point: ") Dim pointPromptResult = docEd.GetPoint(pointPromptOptions) 'If pick point is valid If pointPromptResult.Status <> PromptStatus.OK Then Return End If 'Set value from point prompt result Dim firstSelectedPoint = pointPromptResult.Value 'Start second point prompt point option pointPromptOptions.Message = vbLf & "Specify second point: " pointPromptOptions.UseBasePoint = True pointPromptOptions.BasePoint = firstSelectedPoint pointPromptResult = docEd.GetPoint(pointPromptOptions) 'If pick point is valid If pointPromptResult.Status <> PromptStatus.OK Then Return End If 'Set value from point prompt result Dim secondSelectedPoint = pointPromptResult.Value 'Get vector between fisrt and second selected 3d points Dim selectedVector As Vector3d = firstSelectedPoint.GetVectorTo(secondSelectedPoint) 'Get x and y from vector as double Dim selectedVectorPointY As Double = selectedVector.Y Dim selectedVectorPointX As Double = selectedVector.X 'Apply move to each selected cogo point For Each cogoPointSelectedObject In cogoPointSelectionSet 'Start the transaction Using trans As Transaction = curDb.TransactionManager.StartTransaction() 'Set dbobject and open for write Dim cogoPointDbOj As Autodesk.AutoCAD.DatabaseServices.DBObject = trans.GetObject(cogoPointSelectedObject.ObjectId, OpenMode.ForWrite) 'Set and cast point Dim acCogoPoint As CogoPoint = TryCast(cogoPointDbOj, CogoPoint) 'Get cogo point label location and add vector Dim newCogoPointLabelY As Double = acCogoPoint.LabelLocation.Y + selectedVectorPointY Dim newCogoPointLabelX As Double = acCogoPoint.LabelLocation.X + selectedVectorPointX 'Set the new cogo point label location acCogoPoint.LabelLocation = New Point3d(newCogoPointLabelX, newCogoPointLabelY, 0) 'Save the changes and dispose of the transaction trans.Commit() End Using Next End If 'Regen and update screen docEd.UpdateScreen() docEd.Regen() Catch ex As Exception
