Hatch does not work
Hatch does not work
wesbird
Hatch does not work
wesbird
hi:
I have code to hatch 100+ LWPOLYLINE, for some reason, some of them not working. I check the code, I got error message of
eInvalidInput
at line of
oHatch.AppendLoop(HatchLoopTypes.Default, ObjIds);
I already tried HatchLoopTypes.External, same result.
for testing, I create a function: pick the pline, then call the function, got the same error.
if I manually pick the same pline, use AutoCAD HATCH command, it works.
what's could be wrong?
I really appreciate your help.
private static Entity DrawHatch(Entity ent, Color color)
            string HatchPattern = "SOLID";
            Transparency HatchTransparency = new Transparency(255);
            ObjectIdCollection ObjIds = new ObjectIdCollection();
            ObjIds.Add(ent.ObjectId);
            try
                ent.UpgradeOpen();
                Hatch oHatch = new Hatch();
                oHatch.SetDatabaseDefaults();
                oHatch.SetHatchPattern(HatchPatternType.PreDefined, HatchPattern);
                // color
                oHatch.Color = color;
                // transparency
                oHatch.Transparency = HatchTransparency;
                // Outermost
                // evaluate hatch
                oHatch.EvaluateHatch(true);
                return oHatch;
            catch (Exception caught)
                BPLog.Fatal($"ent={ent.Handle}", caught);
                return null;
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
hng_kaijianG7MAN
Community Visitor
Community Visitor
@wesbird
Hi there, you need to append to block table record before editing the properties of the hatch.
Please refer: Solved: AutoCAD .NET - Creating hatch from polyline - Autodesk Community - AutoCAD
wesbird
Thank you, @hng_kaijianG7MAN,
Sorry, my code is not complete. I do have code for  appending to block table record
also, I tested with this code from gile.  still the same error.
I just don't understand, why the same code work for some pline but not the other, why the same pline code not working but HATCH command works.
and the test pline with problem does not have issue like open, self intersect.
here code from gile
[CommandMethod("JGC.UI.Test", nameof(JGCTest_Hatch2), CommandFlags.Modal)]
        public static void JGCTest_Hatch2()
            var oid = JTISelect.GetEntityX<Polyline>("\nPick a polyline:", "");
            if (oid.IsNull)
                return;
            HatchPolyLine(oid);
        public static void HatchPolyLine(ObjectId plineId)
            try
                if (plineId.IsNull)
                    throw new ArgumentNullException("plineId");
                if (plineId.ObjectClass != RXObject.GetClass(typeof(Polyline)))
                    throw new Autodesk.AutoCAD.Runtime.Exception(ErrorStatus.IllegalEntityType);
                var ids = new ObjectIdCollection();
                ids.Add(plineId);
                using (var tr = plineId.Database.TransactionManager.StartTransaction())
                    var pline = (Polyline)tr.GetObject(plineId, OpenMode.ForWrite);
                    if (!(pline.Closed || pline.GetPoint2dAt(0).IsEqualTo(pline.GetPoint2dAt(pline.NumberOfVertices - 1))))
                        throw new InvalidOperationException("Opened polyline.");
                    var owner = (BlockTableRecord)tr.GetObject(pline.OwnerId, OpenMode.ForWrite);
                    var hatch = new Hatch();
                    hatch.SetHatchPattern(HatchPatternType.PreDefined, "SOLID");
                    owner.AppendEntity(hatch);
                    tr.AddNewlyCreatedDBObject(hatch, true);
                    hatch.Associative = true;
                    hatch.AppendLoop(HatchLoopTypes.Default, ids);
                    hatch.EvaluateHatch(true);
                    tr.Commit();
            catch (System.Exception ex)
                var ed = Application.DocumentManager.MdiActiveDocument.Editor;
                ed.WriteMessage($"{ex.Message}\n{ex.StackTrace}");
_gile
Is the selected pline correctly closed?
Gilles Chanteau
GileCAD
GitHub
wesbird
Thank you, gile,
Yes, it's closed. and HATCH command works just fine.
shubhamraut221195
Most probably your entity is not closed entity. if you draw circle and fill it with hatch it won't show such error but if you do the same with line, it will cause eInvalidInput error at AppendLoop()
