GetPoint ou GetDistance
O_Eckmann
O_Eckmann
I try to insert a block by clicking 3 points to obtain rotation, XScale and YScale. But with the third point I recalculate height of my rectangle
So for third point I use GetPoint, but I'd like user can directly enter the height of rectangle.
If user enter a numeric value, it is used to recreate point 3 in the direction of my mouse.
I could use a keyword to switch to Getdistance mode, or perhaps with an inputpointmonitor, but is there a simple solution to know if a point is clicked or if a value is enter at GetPoint request?
Olivier
Olivier Eckmann
cuongtk2
Type a double value in Getpoint prompt.
_gile
Try this way:
double height = new Line3d(pt1, pt2).DistanceTo(pt3);
Gilles Chanteau
GileCAD
GitHub
O_Eckmann
Hi @cuongtk2 ,
Sorry, but I don't understand your answer. I can enter an integer or a real value, it's always used as a distance to recalculate a point form my basepoint in the direction of my mouse.
I've made a screencast of my behaviour. The goal is to mimic Distance option by just knowing if user has clicked a point or has entered a value.
Olivier Eckmann
O_Eckmann
Hi @_gile ,
Thanks for your method, but my problem isn't to calculate the perpendicular distance from point 3 to segment 1-2, but to know if user has picked a point or has entered a value when GetPoint ask to click a point (form my base point).
Olivier Eckmann
norman.yuan
I assuming what you are asking is how to allow you either select a point, or enter a number during GetPoint() call without having to force user to choose a keyword to switch to GetDistance().
You can set AllowArtibaryInput property of PromptPointOptions to true. Then when testing PromptStatus to be either OK for point clicking, or Other for whatever user entered value. You, of course need to test whether the entered value is a valid numeric value: if the value is invalid, you may want to loop back to rerun the GetPoint() call.
You can do the same by calling GetDistance(), instead of GetPoint(). That is the arbitary value input must be a valid point input.
Norman Yuan
Drive CAD With Code
O_Eckmann
Hi @norman.yuan ,
That's what I want.
I've already tested this solution, but I hadn't seen that the status was keyword. I thought it was OK.
Thanks a lot.
Olivier Eckmann
