GET THE DISPLAYING COORDINATES OF A VIEWPORT OBJECT
inversiones_edgar_itriago
Please I need Help!!! I hope that you may Help me..I have a Viewport rectangular object located in any paper space (layout1 for example) , which is displaying a certain area of the model space, I want to get the lower left and upper right coordinates (x,y) of that area I'm visualizing with the viewport object.
Thanks in advance
_gile
Hi
You can use these extension methods (from GeometryExtensions).
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
namespace GeometryExtensions
    /// <summary>
    /// Provides extension methods for the Viewport type.
    /// </summary>
    public static class ViewportExtensions
        /// <summary>
        /// Gets the transformation matrix from the specified model space viewport Display Coordinate System (DCS)
        /// to the World Coordinate System (WCS).
        /// </summary>
        /// <param name="vp">The instance to which this method applies.</param>
        /// <returns>The DCS to WDCS transformation matrix.</returns>
        public static Matrix3d DCS2WCS(this Viewport vp)
            return
                Matrix3d.Rotation(-vp.TwistAngle, vp.ViewDirection, vp.ViewTarget) *
                Matrix3d.Displacement(vp.ViewTarget - Point3d.Origin) *
                Matrix3d.PlaneToWorld(vp.ViewDirection);
        /// <summary>
        /// Gets the transformation matrix from the World Coordinate System (WCS)
        /// to the specified model space viewport Display Coordinate System (DCS).
        /// </summary>
        /// <returns>The WCS to DCS transformation matrix.</returns>
        public static Matrix3d WCS2DCS(this Viewport vp)
            return vp.DCS2WCS().Inverse();
        /// <summary>
        /// Gets the transformation matrix from the specified paper space viewport Display Coordinate System (DCS)
        /// to the paper space Display Coordinate System (PSDCS).
        /// </summary>
        /// <returns>The DCS to PSDCS transformation matrix.</returns>
        public static Matrix3d DCS2PSDCS(this Viewport vp)
            return
                Matrix3d.Scaling(vp.CustomScale, vp.CenterPoint) *
                Matrix3d.Displacement(vp.CenterPoint.GetAsVector()) *
                Matrix3d.Displacement(new Vector3d(-vp.ViewCenter.X, -vp.ViewCenter.Y, 0.0));
        /// <summary>
        /// Gets the transformation matrix from the Paper Space Display Coordinate System (PSDCS)
        /// to the specified paper space viewport Display Coordinate System (DCS).
        /// </summary>
        /// <returns>The PSDCS to DCS transformation matrix.</returns>
        public static Matrix3d PSDCS2DCS(this Viewport vp)
            return vp.DCS2PSDCS().Inverse();
Here's a testing command which draws a Polyline3d in the model space figuring the selected viewport extents.
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using GeometryExtensions;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(ViewportToWorldCoordinates.Commands))]
namespace ViewportToWorldCoordinates
    public class Commands
        [CommandMethod("Test", CommandFlags.NoTileMode)]
        public void Test()
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var options = new PromptSelectionOptions();
            options.MessageForAdding = "\nSelect a viewport: ";
            options.SelectEverythingInAperture = true;
            options.SingleOnly = true;
            var filter = new SelectionFilter(new[] { new TypedValue(0, "VIEWPORT") });
            var selection = ed.GetSelection(options, filter);
            if (selection.Status != PromptStatus.OK)
                return;
            using (var tr = db.TransactionManager.StartTransaction())
                var vp = (Viewport)tr.GetObject(selection.Value[0].ObjectId, OpenMode.ForRead);
                var extents = vp.GeometricExtents;
                var xform = vp.DCS2WCS() * vp.PSDCS2DCS();
                var vertices = new Point3dCollection();
                vertices.Add(extents.MinPoint.TransformBy(xform));
                vertices.Add(new Point3d(extents.MaxPoint.X, extents.MinPoint.Y, 0.0).TransformBy(xform));
                vertices.Add(extents.MaxPoint.TransformBy(xform));
                vertices.Add(new Point3d(extents.MinPoint.X, extents.MaxPoint.Y, 0.0).TransformBy(xform));
                Polyline3d pline = new Polyline3d(Poly3dType.SimplePoly, vertices, true);
                var modelSpace = (BlockTableRecord)tr.GetObject(
                    SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForWrite);
                modelSpace.AppendEntity(pline);
                tr.AddNewlyCreatedDBObject(pline, true);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
_gile
Here's another testing command which draws a point (nodal) in paper space on the center of each circle entirely visible in the (rectangular) viewport.
the command works whatever the model space current UCS and whatever the view in the viewport.
[assembly: CommandClass(typeof(TransSpacialTranformations.Commands))]
namespace TransSpacialTranformations
        [CommandMethod("CENTERMARK", CommandFlags.NoTileMode)]
        public void CenterMark()
            // switch to paper space if a viewport is activated
            if ((short)AcAp.GetSystemVariable("CVPORT") != 1)
                ed.SwitchToPaperSpace();
            // select a viewport
            options.MessageForAdding = "\nSelect a rectangular viewport: ";
                return;
                // get the viewport extents (paper space coordinates)
                double x1 = extents.MinPoint.X, y1 = extents.MinPoint.Y;
                double x2 = extents.MaxPoint.X, y2 = extents.MaxPoint.Y;
                // activate the selected viewport
                ed.SwitchToModelSpace();
                AcAp.SetSystemVariable("CVPORT", vp.Number);
                // compute the transformation matrix from paper space coordinates to model space current UCS
                var wcs2ucs = ed.CurrentUserCoordinateSystem.Inverse();
                var psdcs2ucs = wcs2ucs * vp.DCS2WCS() * vp.PSDCS2DCS();
                // compute the model space UCS polygon vertices corresponding to the viewport extents
                var polygon = new Point3dCollection();
                polygon.Add(new Point3d(x1, y1, 0.0).TransformBy(psdcs2ucs));
                polygon.Add(new Point3d(x2, y1, 0.0).TransformBy(psdcs2ucs));
                polygon.Add(new Point3d(x2, y2, 0.0).TransformBy(psdcs2ucs));
                polygon.Add(new Point3d(x1, y2, 0.0).TransformBy(psdcs2ucs));
                // select circles within the polygon
                filter = new SelectionFilter(new[] { new TypedValue(0, "CIRCLE") });
                selection = ed.SelectWindowPolygon(polygon, filter);
                    return;
                // collect the selected circles centers transformed into paper space coordinates
                var centers = new Point3dCollection();
                var wcs2psdcs = vp.DCS2PSDCS() * vp.WCS2DCS();
                foreach (SelectedObject so in selection.Value)
                    var circle = (Circle)tr.GetObject(so.ObjectId, OpenMode.ForRead);
                    centers.Add(circle.Center.TransformBy(wcs2psdcs));
                // switch back to paper space
                // add a point (nodal) in paper space on the center of the selected circles
                var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                foreach (Point3d pt in centers)
                    DBPoint point = new DBPoint(pt);
                    curSpace.AppendEntity(point);
                    tr.AddNewlyCreatedDBObject(point, true);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Hi Guilles, thanks for the answers, it looks interesting, I look forward to reviewing... but have another problem, I could not test it because I have my installation of AutoCAD 2016 was a trial version and expired two days ago,  :'-(   Help!
_gile
Sorry but I can't help you for your license problem.
Gilles Chanteau
GileCAD
GitHub
hello, I could test the code you suggested, it's perfect, thank you!
