Get Dwg/Dxf file data into JSON format in Asp.Net application
Get data from the link https://dwgmodels.com/1034-modern-house.html and export it content into JSON format.
you  want to get EVERYTHING from the DXF/DWG into the JSON file??!?!
For DXF I would recommend this library, very easy to parse objects, maybe you can even serialize some automatically:
https://www.nuget.org/packages/netDXF/
