.NET
Form on top of the application
2 REPLIES 2
260 Views, 2 Replies
I have created a Form and I would like the user to populate the form before the form disappears, however at the current time the user can just move the form to the side and keep using cad. I it possible to make sure the form is on top of the application like in VBA?
Thank you in advance,
-J
2 REPLIES 2
michael_robertson
Without seeing your code I'm assuming you are using Form.Show to make your form visible, try Form.ShowDialog instead. This will make your form a Model dialog where the user has to address the form and closs it before any further processing will occur.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
in reply to: michael_robertson
Thank you very much Micheal!!!!!!
I have tryed just about everything (Form.TopMost=True with a timer Smiley Sad).
Simple and to the point . . . .  thank you again Micheal.
-j
Forma Design Contest
