Focus on a specific ObjectId via API
eduardo_salvador02
eduardo_salvador02
Can anyone tell me how I can recreate the function that focuses on an object in AutoCAD through the .NET API?
I'm trying but I only managed to do it for 2D, for 3D it gets lost and focuses on an empty place.
My code that I was testing:
public static void FocusOnObject(ObjectId objId)
    Document doc = AcadApp.DocumentManager.MdiActiveDocument;
    Editor ed = doc.Editor;
    if (objId == ObjectId.Null)
        ed.WriteMessage($"\nItem inválido!\n");
        return;
    using (Transaction tr = doc.TransactionManager.StartTransaction())
        try
            Entity entity = tr.GetObject(objId, OpenMode.ForRead) as Entity;
            if (entity != null)
                ed.SetImpliedSelection(new ObjectId[] { objId });
                if (entity.Bounds.HasValue)
                    Extents3d extents = entity.GeometricExtents;
                    using (ViewTableRecord view = ed.GetCurrentView())
                        Point3d minPt = extents.MinPoint;
                        Point3d maxPt = extents.MaxPoint;
                        Point3d center = new Point3d(
                            (minPt.X + maxPt.X) / 2.0,
                            (minPt.Y + maxPt.Y) / 2.0,
                            (minPt.Z + maxPt.Z) / 2.0);
                        double margin = 0.1; // 10% of margin
                        double width = (maxPt.X - minPt.X) * (1 + margin);
                        double height = (maxPt.Y - minPt.Y) * (1 + margin);
                        double depth = (maxPt.Z - minPt.Z) * (1 + margin);
                        view.Target = center;
                        view.Height = height;
                        view.Width = width;
                        view.ViewDirection = new Vector3d(view.ViewDirection.X, view.ViewDirection.Y, 1.0);
                        if (depth > height && depth > width)
                            view.LensLength = depth;
                        ed.SetCurrentView(view);
                else
                    ed.WriteMessage("\nA entidade não possui extents válidos.");
            tr.Commit();
        catch (System.Exception ex)
            ed.WriteMessage($"Erro ao focar no objeto: {ex.Message}");
_gile
You have to transform the extents of the entity from World coordinates (WCS) to the current view display coordinates (DCS) before usint it to define the view center and size.
Here's an example from your code integrating some code from this library ( specifically AbstractViewTableRecordExtension and EditorExtension ).
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    if (objId.IsNull)
        return;
    using (Transaction tr = db.TransactionManager.StartTransaction())
        try
            if (entity != null)
                        Matrix3d worldToEye =
                            Matrix3d.WorldToPlane(view.ViewDirection) *
                            Matrix3d.Displacement(view.Target.GetAsVector().Negate()) *
                            Matrix3d.Rotation(view.ViewTwist, view.ViewDirection, view.Target);
                        extents.TransformBy(worldToEye);
                        view.Width = extents.MaxPoint.X - extents.MinPoint.X;
                        view.Height = extents.MaxPoint.Y - extents.MinPoint.Y;
                        view.CenterPoint = new Point2d(
                            (extents.MaxPoint.X + extents.MinPoint.X) / 2.0,
                            (extents.MaxPoint.Y + extents.MinPoint.Y) / 2.0);
                else
            tr.Commit();
Referencing Gile.AutoCAD.R20.Extension.dll (or Gile.AutoCAD.R25.Extension.dll for AutoCAD 2025), you could simply write:
    var ed = Active.Editor;
    if (objId.IsNull)
        return;
    using (var tr = Active.Database.TransactionManager.StartTransaction())
        try
            if (objId.TryGetObject(tr, out Entity entity))
                    ed.Zoom(entity.GeometricExtents);
                else
            tr.Commit();
Gilles Chanteau
GileCAD
GitHub
eduardo_salvador02
Thank you very much, this solved my need.
