Find xref object layer
ralstogj
ralstogj
Hi
I am trying to write an app to check all xref objects are on the correct layer according to our office standards. In a project folder that contains a number of dwgs.
Typical we want an xref object inserted on a layer X-FileName.
I have gotten the code at the following link up an running that lets me select a folder and then loops thru the dwgs in the folder and finds the xrefs in each dwg.
https://forums.autodesk.com/t5/net/net-c-updating-xref-path-without-opening-the-drawing/td-p/3566486
I am now stuck at what I need to insert to select the xref object and find the layer it is inserted on.
Is someone able to provide a sample of the code demonstrating now one would find the xref layer.
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
ralstogj
modified some code from a blog post to find the xref object in the database and layer.
[CommandMethod("XP_FindxrefsLayer")]
public void ChangeXref()
// this code is modified from this blog post
//http://through-the-interface.typepad.com/through_the_interface/2015/01/modifying-the-contents-of-an-...
var doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
if (doc == null)
return;
var ed = doc.Editor;
var db = doc.Database;
// Get the database associated with each xref in the
// drawing and change all of its circles to be dashed
using (var tr = db.TransactionManager.StartTransaction())
var bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
var ms =(BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
// Loop through the contents of the modelspace
foreach (var id in ms)
// We only care about BlockReferences
var br =tr.GetObject(id, OpenMode.ForRead) as BlockReference;
if (br != null)
// Check whether the associated BlockTableRecord is
// an external reference
var bd =(BlockTableRecord)tr.GetObject(br.BlockTableRecord, OpenMode.ForRead);
if (bd.IsFromExternalReference)
// If so, get its Database and call the function
// to change the linetype of its Circles
String xreflayer =br.Layer;
String xrefname = br.Name;
ed.WriteMessage("\nthe xref is inserted on the layer" + xreflayer);
ed.WriteMessage("\nthe xref name is " + xrefname);
tr.Commit();
Regards
Justin Ralston
