Filter Pickfirst Selectionset
SRSDS
Advisor Advisor
SRSDS
I want to use the pickfirst (UsePickSet) selection then filter that selection to make sure I'm only modifying a certain dynamic block.
I have a selection filter set up for the named dynamic block (and use it for the ed.GetSelection method) but I don't know how to apply it to the returned pickfirst selection.
Is this possible?
SRSDS
It was easy enough to step through all the selected elements checking block names and adding them to an Idcollection.
Maybe I Just wondered if there was a more elegant way like the getselection filter.
_gile
With CommandFlags.UsePickSet, the selection filter passed to the EditorGetSelection() method is automatically applied to the active selection if any.
You can with try this little snippet both ways: selecting blocks and other entites before or after launching the TEST command.
        [CommandMethod("Test", CommandFlags.UsePickSet)]
        public void Test()
            Document doc = AcAp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            TypedValue[] filter = { new TypedValue(0, "INSERT") };
            PromptSelectionResult psr = ed.GetSelection(new SelectionFilter(filter));
            if (psr.Status != PromptStatus.OK) return;
using (Transaction tr = db.TransactionManager.StartTransaction()) { foreach (SelectedObject obj in psr.Value) { BlockReference br = (BlockReference)tr.GetObject(obj.ObjectId, OpenMode.ForWrite); br.Color = Color.FromColorIndex(ColorMethod.ByAci, 30); } tr.Commit(); } }
Gilles Chanteau
GileCAD
GitHub
SRSDS
That simplifies things.
I was following an example I found which was different and made things slightly more complicated.
http://through-the-interface.typepad.com/through_the_interface/2006/09/using_the_pickf.html
Thankyou
