eWasErased
eWasErased
eWasErased
HI I am new to VB.NET.
I am trying to use the code provided on:
http://through-the-interface.typepad.com/through_the_interface/2007/07/updating-a-sp-1.html
The only thing is I have translated it to VB.NET instead.  (this could be the problem I am sure)
I am opening the Database of all the drawings (from the file) stepping thru each object and then looking for the attribute to change.
If I have a drawing with 1 object (a block with the attributes I want to edit) in it the code works fine.  But if I add a line to the file it fails.
It fails just after the first For each entid....
Dim Ent As Entity = TR.GetObject(entId, OpenMode.ForRead)
    Private Function UpdateAttributesInBlock(Byref DB As Database, ByVal btrID As ObjectId) As Integer
        Dim Doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim Ed As Editor = Doc.Editor
        Dim ChangeIndex As Integer, Intchanged As Integer
        Dim TR As Transaction = DB.TransactionManager.StartTransaction
        Using TR
            Dim btr As BlockTableRecord = TR.GetObject(btrID, OpenMode.ForRead)
            For Each entId As ObjectId In btr
                If Ent <> Nothing Then 'And Ent.GetType.ToString = "Autodesk.AutoCAD.DatabaseServices.BlockReference" Then
                    Dim br As BlockReference = Ent
                    If br <> Nothing Then
                        Dim bd As BlockTableRecord = TR.GetObject(br.BlockTableRecord, OpenMode.ForRead)
                        'does the mSheet array contain current Block Name
                        If mSheets.Contains(bd.Name.ToUpper) = True Then
                            'step thru all sheet
                            For Each Sheet As String In mSheets
                                'if next sheet contains block name
                                If Sheet.ToUpper = bd.Name.ToUpper Then
                                    'step thru all attributes
                                    For Each arid As ObjectId In br.AttributeCollection
                                        Dim obj As DBObject = TR.GetObject(arid, OpenMode.ForRead)
                                        Dim ar As AttributeReference = obj
                                        'if current sheet change, and attribute matches then change text value
                                        If ar.Tag.ToUpper = mAttributes.GetValue(ChangeIndex).ToString.ToUpper Then
                                            ar.UpgradeOpen()
                                            ar.TextString = mChangeValues.GetValue(ChangeIndex).ToString
                                            'added to fix alignment issue
                                            Dim WDB As Database = HostApplicationServices.WorkingDatabase
                                            HostApplicationServices.WorkingDatabase = DB
                                            ar.AdjustAlignment(DB)
                                            HostApplicationServices.WorkingDatabase = WDB
                                            ar.DowngradeOpen()
                                            Intchanged = 1
                                    Next
                                ChangeIndex = ChangeIndex + 1
                            Next
                            ChangeIndex = 0
            Next
            TR.Commit()
        End Using
        Ed.WriteMessage(Intchanged.ToString + " ITEMS CHANGED!" + vbCrLf)
        Return Intchanged
    End Function
Some help would be greatly appreciated.
Merry Christmas.
Stephan
Try changing the line that fails to
Dim Ent As Entity = TR.GetObject(entId, OpenMode.ForRead, True)
This will return the entity instead of throwing the eWasErased error. Although you have to be aware that the entity returned has been erased from the drawing. AutoCAD does not clean up erased items until you save the drawing.
Fantastic.... Smiley Happy
Thanks So much.
