Enum DwgVersion VS AutoCAD Version?
swaywood
swaywood
Hi:
I want to know where can i find it.
I tried to looking for it in the ARX helper file, but not found.
norman.yuan
If you downloaded ObjectARX SDK, in its folder "\Docs", there should be a "arxmgd.chm" (Managed .NET Reference Guide), in the "Index" tab, enter/search "DwgVersion Enumeration". I am not sure what ARX help file you have looked at, but the one I mentioned exists in every version of ARX SDK.
Norman Yuan
Drive CAD With Code
swaywood
Hi,Yuan:
Thanks.
I means, I can't see the corresponding AutoCAD version from these enumeration values.
AC1001 = 8
AC1002 = 9
AutoCAD 2.5
AC1003 = 10
AutoCAD 2.6
AC1004 = 11
Release 9
AC1005 = 12
AC1006 = 13
Release 10
AC1007 = 14
AC1008 = 15
AC1009 = 0x10
R11 and R12
AC1010 = 0x11
AC1011 = 0x12
AC1012 = 0x13
R13
AC1013 = 20
AC1014 = 0x15
R14
AC1015 = 0x17
AC1021 = 0x1b
2007 Final
AC1500 = 0x16
AC1800 = 0x19
2004 final
AC1800a = 0x18
2004 mid version
AC1To2 = 1
AC1To40 = 2
AC1To50 = 3
AC2100a = 0x1a
AC2To10 = 5
AC2To20 = 4
AC2To21 = 6
AC2To22 = 7
_gile
This is not the AutoCAD version, this is the DWG version.
See this table (DWG format).
Gilles Chanteau
GileCAD
GitHub
swaywood
Hi,Giles: Thank you so much.
