eInvalidInput error
eInvalidInput error
eInvalidInput error
Line line = new Line(ptStart, ptEnd);
Vector3d vec = new Vector3d();
Point3d ptd1 = new Point3d();
vec = line.GetFirstDerivative(ptd1).GetNormal(); //eInvalidInput
ptStart coordinate is (655275600.438987,36192616.8036762,0)
ptEnd coordinate is (655295053.399808,36189883.0214896,0)
Why am I always getting "eInvalidInput" error. Any help would be greatly appreciated.
BKSpurgeon
 [CommandMethod("testDerivative")]
        public static void TestLine()
            //// Your start points
            // Point3d p1 = new Point3d(655275600.438987, 36192616.8036762, 0);
            // Point3d p2 = new Point3d(655295053.399808, 36189883.0214896, 0);
            Point3d p1 = new Point3d(0, 0, 0);
            Point3d p2 = new Point3d(10, 0, 0);
            Point3d p3 = new Point3d(5, 0, 0);
            using (Line ln = new Line(p1, p2))
                vec = ln.GetFirstDerivative(p3).GetNormal();
  • Try the above code - it works for me.
  • I think the error is coming because the p3 (i.e. the point supplied to the GetFirstDerivative method is not on the line itself. Solution is to: supply a point on the line.
  • Also I think you should dispose of your Line explicitly or use a `using` statement..
_gile
It's because ptd1 (initialized to 0,0,0) does not lies on the line.
If you want to get the direction vector of the line, you can simply do:
vec = ptStart.GetVectorTo(ptEnd).GetNormal();
 or:
vec = (ptEnd - ptStart).GetNormal()
Gilles Chanteau
GileCAD
GitHub
