Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
.NET
Editor.Command equivalent for pre-2015?
2 REPLIES 2
mhillis
409 Views, 2 Replies
Hello all,
Quick question - is there an equivalent function to Editor.Command in pre-2015 version of AutoCAD?  The routine is nifty and I love it, but unfortunately, being restricted to 2015+ has its own issues.
I've tried using Document.SendStringToExecute for the particular application I'm needing it for; however, that does not work since I'm needing to do something in the middle of a routine.
Anyone have any suggestions?
Thanks!
2 REPLIES 2
_gile
in reply to: mhillis
You can use Tony "DiningPhilosopher" Tanzillo's wrapper for the non-public RunCommand() method (second reply of this thread).
Gilles Chanteau
GileCAD
GitHub
mhillis
in reply to: _gile
Gile,
That was it, on the nose I might add.  Thank you!
AutoCAD Inside the Factory
