.NET
Dynamic block repositioning issue: Attributes stay, but Mtext moves
12 REPLIES 12
Message 1 of 13
OrmArTHe
294 Views, 12 Replies
Hi guys!
I'm trying to reposition the base point of a Dynamic block after it is added to the database.
The block consists of 5 Attributes and 1 Mtext.
The expected behaviour is that Attributes and Mtext stay at the current position, and only the base point and custom grips are repositioned.
What I get is: Attributes stay but Mtext moves along with the base point and custom grips.
Any ideas why this is happeneing and how to resolve it?
I've attached the dwg file.
12 REPLIES 12
Message 2 of 13
_gile
in reply to: OrmArTHe
Hi
You could "synchronize" the attributes, but it is simpler to use TransformBy method to displace a block reference (and its atributes will be displaced at the same time).
Gilles Chanteau
GileCAD
GitHub
Message 3 of 13
OrmArTHe
in reply to: _gile
How do I "synchronize" the attributes? What came to my mind is a workaround: change that Mtext to Attribute - that should hopefully make it stay in place.
If TransformBy displaces attributes - that is not what I want. I want all the blocks' content to stay in place, and only reposition its base point (I don't care if custom grips are repositioned or not).
Edit: Forgot to attach the block. It's now attached to my first post.
Message 4 of 13
_gile
Sorry, I do not fully understand what you're trying to do when you say: "reposition its base point".
Are you talking about the block definition (BlockTableRecord) or an inserted reference (BlockReference)?
Gilles Chanteau
GileCAD
GitHub
Message 5 of 13
OrmArTHe
in reply to: _gile
Sorry for not being explicit enough... I'm talking about inserted BlockReference.
Message 6 of 13
_gile
Please show the code that you have written and that "don't work" for you.
And perhaps explain how you'd "reposition its base point" without coding.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 13
OrmArTHe
in reply to: _gile
In my opinion, It is not that the code isn't working, but I just want to know why is Mtext moving and Attribute is not moving.
Actually, what I'm trying to do is to automate the process of manually repositioning the block reference as well as its attributes. Manual process involved repositioning the block using base point grip and a few custom grips. The manual steps were as follows:
1) Reposition the base point to location 1.
2) Reposition the attributes using custom grips to location 2.
Current automatic steps (with coding):
1) Reposition the base point to location 1 using `blkRef.Position = newPosition;`.
2) Reposition the attributes to location 2 by changing the values of dynamic block properties (e.g. `prop.Value = newValue;`).
The code works as expected albeit the Mtext is moved to location 1. This behaviour is explained by Mtext not being an attribute. So I was wandering if there is a way to keep Mtext from moving to location 1?
Message 8 of 13
_gile
No way. This is how AutoCAD blocks work. You cannot change an entity in a block reference (except attribute references), you have to change it in the block definition and doing so will affect all inserted references.
Gilles Chanteau
GileCAD
GitHub
Message 9 of 13
OrmArTHe
in reply to: _gile
What changes should I make in block definition so that Mtext doesn't move  to location 1?
Message 10 of 13
_gile
What changes should I make to block definition so that Mtext doesn't move  to location 1?
Sorry if I was not clear. What you're asking is not possible, any tranformation to a block reference will affect all the displayed entities (with an exception for attributes)
You should learn how AutoCAD blocks work (read this topic).
A block definition (BlockTableRecord) is a collection of entities. A block reference (BlockReference) does not contains entities, it is only a reference to the block definition with linear transformations (displacement, rotation and scaling) which affect all the displayed entities.
Only the attributes work a little differently. The block definition may contain attribute definitions (AttributeDefinition) and, as shown in another of your posts, when creating a new BlockReference by code, we have to explicitly create an attribute reference in the block reference AttributeCollection for each AttributeDefinition in the block definition. This is why, unlike other entities, attribute references may be slightly different from their attribute definition (position, text string).
In your case, you should replace the MText (/) with a Constant attribute definition and add it to the selection set of the action of Position1 parameter so that it can be displaced with other attributes.
Gilles Chanteau
GileCAD
GitHub
Message 11 of 13
OrmArTHe
in reply to: _gile
Thank you for the detailed response.
I did this and still, the issue persists... Block attached.
Message 12 of 13
_gile
My mistake, do not set the attribute definition Constant.
Gilles Chanteau
GileCAD
GitHub
Message 13 of 13
OrmArTHe
in reply to: _gile
Thanks!
AutoCAD Inside the Factory
