DocumentManager.Open() Is Not the current Document
Message 1 of 10
I used autocad 2012,when I use code to open a drawing like below:
Application.DocumentManager.MdiActiveDocument = Application.DocumentManager.Open(path, false);
Document doc = Application.DocumentManager.MdiActiveDocument;
            doc.LockDocument();
I got a document, but the document is not what i open, it's the previous document.
Anyone can tell me how to get the document I opened right now~?
Any of your help will do me a big favor,
thank you.
Replies (9)
Message 2 of 10
_Tharwat
This is what I use:
public static void OpenCadDrawing()
            DocumentCollection d = Application.DocumentManager;
            string FileName = "C:\\Test.dwg"; // Add your full path of the drawing
            if (File.Exists(FileName))
                Document doc = d.Open(FileName, false);
                d.MdiActiveDocument = doc;
            else
                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\nDrawing can not be found !");
Message 3 of 10
I tried your solution,
but the code can not go on when it goes to
the codes after this could not be called..
Message 4 of 10
Actually, I tried your way,and here is what I have problem with
when I tried to call
Application.DocumentManager.MdiActiveDocument.Name
The result is still the previous document,Not the one I Opened it right now...
Message 5 of 10
_Tharwat
If the problem is only with activating the drawing, try to set the WindowState of the newly opened drawing to Maximized as in the following example.
e.g;
doc.Window.WindowState = DocumentWindow.State.Maximized;
And you need to add the namespace :
using Autodesk.AutoCAD.Windows;
EDIT: I made the Window state to Maximized as you wish for.
Message 6 of 10
I can't using the
the visual studio always remind me to add use of PresentationCore.dll
Even when I add the namespace before the Window will still get the problem.
have you faced it~?
Message 7 of 10
_gile
If your code is called from a CommandMethod attributed class, you have to set the CommandFlags.Session.
[CommandMethod("Cmd", CommandFlags.Session)]
Gilles Chanteau
GileCAD
GitHub
Message 8 of 10
I just used it in a private function, other place will call the function...
Message 9 of 10
_gile
When I said "called from", I didn't mean "directly called from", I meant the main calling method.
How do you start the process which calls this function? a command or a click on a dialog button? if it's from a dialog, is this dialog modal or modeless? if it's a modal dialog, how is opened this dialog?...
Gilles Chanteau
GileCAD
GitHub
Message 10 of 10
I got it
Thank you...
