Dock Form inside AutoCAD
mcoH3VZV
mcoH3VZV
I have made a windows form that automates large portions of AutoCAD processes. Is there any way to dock this form inside AutoCAD , like a tool pallette? Or do I need to start from scratch with a custom toolbar? Currently I am typing in a command, which opens the form. It is then loose and often gets forgotten underneath the other AutoCAD windows once AutoCAD comes into focus, etc.
Thank you,
norman.yuan
You probably need to understand when to show the Form/UI as Modal, or Modeless Form/Window. Also, do not use Win Form's built-in Form.Show()/ShowDialog() to show form in AutoCAD. Instead, use:
Autodesk.AutoCAD.ApplicationServices.Application.ShowModal[Modeless]Dialog[Window]()
For docking UI, you can look at Autodesk.AutoCAD.Windows.PaletteSet.
In general, for Modeless form/window, or PaletteSet, it usually should be declared as static/Shared in class level, so that only singleton of the UI is created.
Norman Yuan
Drive CAD With Code
_gile
You'll find a minimalist example about creating a PaletteSet here.
Gilles Chanteau
GileCAD
GitHub
