Displaying Direction and Distance of Polyline
dalexanderSP3WJ
dalexanderSP3WJ
Greetings everyone,
I am wondering if there is a method within the .NET API that allows the programmatic display of the bearing and distance of given lines. This is a step beyond just a linear dimension as I am trying to show the direction of a line in degrees, minutes, seconds, format along with its length.
This link gives a more in depth explanation of the Line by Direction and Distance command in AutoCAD Civil 3D:
https://knowledge.autodesk.com/support/civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Civi...
(I have included this for a visual of what I am trying to do)
If there is no singular method that supports this task what approach should I take at trying to build this functionality?
A great thanks to anyone who can help.
dalexanderSP3WJ
This was one of those instances where I was asking the wrong question, in the wrong forum.
Here is the accepted solution to this post:
https://forums.autodesk.com/t5/civil-3d-customization/labeling-lines-with-a-bearing-and-distance/m-p...
