.NET
Display Preview of DWG File in PictureBox
9 REPLIES 9
Message 1 of 10
3229 Views, 9 Replies
I'm trying to display a preview of an AutoCAD file in a PictureBox in VB.Net. I need to find a cheap way to do this and I have not been able to find an inexpensive solution. Is there a way to do this conversion in code?
9 REPLIES 9
Message 2 of 10
Am Mon, 20 Jul 2009 20:31:42 +0000 schrieb vampirefromtheITcave:
> From: vampirefromtheITcave <>
> Subject: Display Preview of DWG File in PictureBox
> Newsgroups: autodesk.autocad.customization.dotnet
> Path: discussion.autodesk.com
> Xref: discussion.autodesk.com autodesk.autocad.customization.dotnet:15614
> Content-Type: text/plain; charset="UTF-8"
> Content-Transfer-Encoding: quoted-printable
> Message-ID: <6221590@discussion.autodesk.com>
> References:
> Date: Mon, 20 Jul 2009 20:31:42 +0000
> I'm trying to display a preview of an AutoCAD file in a PictureBox in VB.Ne=
> t. I need to find a cheap way to do this and I have not been able to find =
You can diplay the preview-bitmap stored in the dwg-file using
dwgthumbnail.ocx. Googling for it will show some download-locations.
HTH
Herbert
Message 3 of 10
cadMeUp
I'm not sure if this has been tried, this will get the thumbnail as an Image object so it can be applied to a PictureBox:
Public Function abortFunc() As Boolean
End Function
Public Sub Asdkcmd1()
Dim myDwg As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim myDB As Database = myDwg.Database
Dim bm As System.Drawing.Bitmap = myDB.ThumbnailBitmap
Dim img As System.Drawing.Image = bm.GetThumbnailImage(bm.Width, bm.Height, New System.Drawing.Image.GetThumbnailImageAbort (AddressOf abortFunc), IntPtr.Zero)
Dim dlg As ThumbnailDialog = New ThumbnailDialog()
dlg.PictureBoxMain.Image = img
dlg.ShowDialog()
End Sub
Though If model space has a black background (Model - 2D Wireframe) the thumbnail ends up with a white background. Does the dwgthumbnail.ocx handle it the correct way? Having trouble finding that file.
Message 4 of 10
IMHO what has happened is that DWGThumbnail.OCX does not display preveiw of files saved with ACAD 2009 upwards.
I thought it was a pretty good of way of displaying previews without having to open the entire database and without having ACAD/RealDWG around.
Message 5 of 10
dwgthumbnail.ocx only allows me to use files up to the 2002 edition of AutoCAD. I need to be able to view files made by AutoCAD 2008. It would be nice if it were also compatible with 2010.
Message 6 of 10
dlg.ShowDialog()
For some reason vb.net does not recognize Document, Database, or ThumbnailDialog. Is there something I need to Import?
Message 7 of 10
cadMeUp
Yeah, as long as you have your AutoCAD references added to your project, you just have to declare your imports at the top of your code file:
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.GraphicsSystem
etc...
Instead of having to type:
dim doc as Autodesk.AutoCAD.ApplicationServices.Document
you just just say:
dim doc as Document
The 'ThumbnailDialog' is just the name of a dialog that I created for this test project, it's just a System.Windows.Forms.Form. It can be any window that you have that has a 'PictureBox' in it:
So if you have a dialog that you are going to display named MyDialog:
Dim dlg as MyDialog = New MyDialog()
dlg.MyPictureBox.Image = img
dlg.ShowDialog()
Message 8 of 10
Am Tue, 21 Jul 2009 13:00:48 +0000 schrieb vampirefromtheITcave:
I'm using 2.0.0.0 and it works with ACAD2010 files as well.
IIRC, there is an updated version available on adn.
Regards
Herbert
Message 9 of 10
I found a vb file called dwgtobmp.vb. I don't remember where I got it because I got it yesterday on one of the forums I was reading. Tested it today and it works well. Thanks for all the help everyone. If I can find the post again, I'll post a link here for anyone who needs it in the future. I'm not sure which versions it works with, but it works for 2008 and I don't foresee any issues with similar versions. I don't know a lot about AutoCAD though, so no guarantees.
Message 10 of 10
cadMeUp
Maybe you can post that file?
Forma Design Contest
