Disable printing documents from preview window programmatically
Can you help me please ?
i'm developping a vb.net plugin for autocad 2013 + a vb.net application, i want to disable printing documents when they are not validated by an admin...
i know two ways to do this : by undefining the Plot command or using the veto command in .net
The problem, i can't control printing from the "Preview window", it does not call the "Plot" command at all from there.
my question: is there a way to get control of this button programmatically ?
or how can'i hide it from the Preview window ?
Virupaksha_aithal
Autodesk Support
Autodesk Support
see if you can block the print comamnd (and any other commans)? Refer blog which explains the procedure to block AutoCAD commands through code http://through-the-interface.typepad.com/through_the_interface/2006/10/blocking_autoca.html
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
