I have problem with below code. I opet transaction, select O (polyline entity).
Entity O have previos added xrecord with name key.
With this code I delete record, but when I finish sub and dispose tranaction trans xrecord
stay in entity... I dont now wath is wrong.
Please Tony T. or some others for some advice...
{code}
Public Shared Sub DeleteXRecord(ByVal o As Entity, ByVal key As String, ByVal trans As Transaction)
Try
Using dict As DBDictionary = TryCast(trans.GetObject(o.ExtensionDictionary, OpenMode.ForWrite, False), DBDictionary)
If dict.Contains(key) Then
Dim objid As ObjectId = dict.GetAt(key)
Dim xRecord As Xrecord = DirectCast(trans.GetObject(dict.GetAt(key), OpenMode.ForWrite), Xrecord)
xRecord.Erase()
dict.Remove(objid)
Else
dict.Dispose()
End Using
Catch ex As Exception
MsgBox("Error")
End Try
End Sub
{code}
