Default directory using Autodesk.AutoCAD.Windows.OpenFileDialog
I am looking to get a directory name from the user but be able to utilize the Autodesk OpenFileDialog (our users have a bunch of shortcuts along the left side). So I set the AllowFoldersOnly flag, but can't seem to get it to go to a specified default directory location. In this case I'm forcing it to C:\temp, but in the full code, I will be deriving this location by other code.
Any help or direction would be greatly appreciated.
thanks
Dim ToDialogRes As System.Windows.Forms.DialogResult
Dim flags As Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags = Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.AllowFoldersOnly
Dim openFileDialog2 As New Autodesk.AutoCAD.Windows.OpenFileDialog("Please Select Target Directory", "C:\temp", "", "Select Directory", flags)
ToDialogRes = openFileDialog2.ShowDialog()
Select Case ToDialogRes
Case System.Windows.Forms.DialogResult.OK
TextBox1.Text = openFileDialog2.Filename
Case System.Windows.Forms.DialogResult.Cancel
MsgBox("User Cancelled")
Case Else
MsgBox("something else")
End Select
antonio.leonardo
Hi @Anonymous,
You can use this approach to define default user folder, in this example bellow, the captured directory will be the Documents folder of current user:
Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments)
The type Environment.SpecialFolder is a enumerator with several options to define Windows User folder, as image bellow from .NET Framework System namespace (or mscorlib assembly):
Att,
Antonio Leonardo
Thanks Antonio for responding,  I really appreciate it, however, my problem is not finding the folder I want to set, it's the actual setting it that is not working for me.  In the code I posted I'm just hardcoding it now to c:\temp, but that is not where the dialog is opening too. That is my problem, it's not recognizing the c:\temp.
So I'm thinking I've got something wrong with the flags, or the syntax on the directory string.
kerry_w_brown
I don't do VB much, but have a look here
https://www.theswamp.org/index.php?topic=46829.0
Kerry,
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
_gile
Try adding the DefaultIsFolder and ForceDefaultFolder flags.
var openFileDialog = new Autodesk.AutoCAD.Windows.OpenFileDialog(
    @"C:\Temp",
    "Select Directory",
    Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.AllowFoldersOnly |
    Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.DefaultIsFolder |
    Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.ForceDefaultFolder);
Gilles Chanteau
GileCAD
GitHub
You are right Gilles, thank you so much, just had to adjust my flags...working like a charm now!
Dim flags As Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags = Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.AllowFoldersOnly _
Or Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.DefaultIsFolder _
Or Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.ForceDefaultFolder
