Custom Variable
Custom Variable
WonkaPet
Custom Variable
WonkaPet
Hi there,
I was just wondering if anyone had a solution to this problem.
Similar to AutoCAD's native OFFSET routine I'd like my routine to be able to "remember" the unit type and the unit value (ie ft / 5.0, m /  5.0). The OFFSET routine is able to remember the unit value using the OFFSETDIST system variable.
Is there anyway to store my own custom variables on a per drawing basis so that if a user opens another drawing I'd be able to display those values in my routine? I don't want to use the USERS1-5 variables if possible.
_gile
You can probably get some inspiration from these old but still relevant topics from Kean Walmsley's blog:
Per-document data in .NET applications - Part 1
Per-document data in .NET applications - Part 2
Gilles Chanteau
GileCAD
GitHub
_gile
You also can register custom system variables.
You can see the Variable class in the developper's documentation and this example at TheSwamp.
Gilles Chanteau
GileCAD
GitHub
