Custom Hatch pattern in code
Hi group,
I have come up short trying to find code for creating custom Hatch pattern
in code rather than having to import a .pat file.  I assume it’s similar to
creating a custom (in code) Linetype but I’m not finding an example anywhere.
Is this possible?
Martin.
Try this:
        [CommandMethod("CreateHatchPattern")]
        public static void CreateHatchPattern()
            string path = Directory.GetParent(Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData)).FullName;
            if (Environment.OSVersion.Version.Major >= 6)
                path = Directory.GetParent(path).ToString();
            //Adjust the Path According to your AutoCad version
            //FileName must be equal to pattern name
            path = path + "\\AppData\\Roaming\\Autodesk\\AutoCAD 2015\\R20.0\\enu\\Support\\Tile Test.pat";
            List<string> Pattern = new List<string>();
            //Pattern see https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Creating-new-Custom-Hatch-patterns.html
            //and https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-in-pattern-file-in-AutoCAD.html
            Pattern.Add("*Tile Test");
            Pattern.Add("45, 0,0, 0,.125");
            Pattern.Add("135, 0,0, .25,.125, .3125,-.1875");
            //Last return needed!
            Pattern.Add("");
            if (!File.Exists(path))
                File.AppendAllLines(path, Pattern);
            else if (File.Exists(path))
                File.Delete(path);
I did'nt use TextWriter because the .pat file is in use.
There are a few rules to be followed when creating custom .pat patterns:
See:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
PS. I suffered from this rules myself.
Thanks Marcos,
I will have a look. 😄
